Kyocera FS1370DN Laser Printer Logo
A
Anonymous Posted on Mar 06, 2014
How to fix call service 7990 0001409 error - Kyocera FS1370DN Laser Printer
What is Error 0x000003eb. Help me fix this error?
Error 0x000003eb is a printer connectivity/installation error. There are various threads on the internet with workarounds and fixes, since I have not tried all of them; I will only be posting the ones that have worked for me.
What's essential to note is the error number; not the error message because this message varies depending on the operating system.
If you are attempting to install a printer, but cannot do so because of the Error Code 0x000003eb, then you are in the right place because we are going to talk today how to solve this problem. The error message does not give you much data because it only indicates that the printer cannot be installed and gives you the error code 0x000003eb.
3 method that resolves Error 0x000003eb:-
Method 1: Check Windows Installer Service.
Method 2: Remove old drivers and then re-install.
Method 3: Delete Printer Keys.
Error 0x000003eb is not resolved, this might mean there's waste within the printer's inside. Call the customer services or check this blog for a full solution.
tip
Error code CANON iR2270 / iR2870 / iR3570 / iR4570 ...
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E713 communication error for finisher
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Regarding most common errors related to fixing section:
E000 The temperature of the fixing assembly is abnormally high.
0001 While startup control is under way, the reading of
the main thermistor is less than 30 deg C
continuously for 200 msec or more 1 sec after the
start of power supply.
the main thermistor is less than 70 deg C
continuously for 200 msec or more 2 sec after the
the main thermistor is less than 120 deg C
continuously for 200 msec 6 sec after the start of
power supply.
The startup control does not end 30 sec after the
Reset the condition in service mode:
COPIER>FUNCTION>CLEAR>ERR. Replace the
main thermistor. Replace the DC controller PCB
E001 The temperature of the fixing assembly is abnormally high.
0000 The reading of the main thermistor is 250 deg C
or more continuously for 200 msec.
0001 The hardware circuit detects overheating of the
main or sub thermistor for 200 msec.
Reset the condition in service mode: COPIER>FUNCTION>CLEAR>ERR. Replace the
E002 The rise in temperature of the fixing assembly is faulty.
0000 While startup control is under way, the reading of
the main thermistor is less than 115 deg C
continuously for 400 msec 1.3 sec after it has
indicated 100 deg C.
the main thermistor is less than 150 deg C
indicated 140 deg C.
E003 The fixing temperature is too low after a standby state.
0000 While regular temperature control is under way,
the reading of the main thermistor is less than 140
deg C continuously for 400 msec or more.
E007 The rotation of the fixing film is faulty.
0000 While the fixing motor is rotating, the marker
signal is not detected for 6 sec with the reading of
the main thermistor indicating 100 deg C or more.
REPLACE FIXING FILM ASSY(HEATER)
To enter service mode:
* 2 8 *
3answers
How to fix Canon MX452 when it shows Error 0x000003eb?
Error 0X000003EB is a very disturbing error. If you are viewing the same crash check this blog and Just understand the steps which are written on the blog to retaliate the Error 0x000003eb. We give online direction for Any problem in Printer Errors.
Error 0X000003EB is a printer error. If you are attempting to connect a printer, but cannot do so because of the error code 0x000003eb, then you are in the fittest place because we are going to explain today how to resolve this problem. The error report does not give you much message because it only means that the printer cannot be connected and provides you the error code 0x000003eb.
Right Steps to Resolve Error 0X000003EB:-
1. Checkout sure Windows Installer Service is running not.
2. Do Perform Clean Boot.
3. Check Registry Fix.
Error 0X000003EB is usually caused by wrongly configured system settings or different entries in the Windows registry. This error can be fixed with this Mentioned Blog.
2answers
Canon printer error code 006
you will have to replace the print head
49helpful
5answers
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
2answers
21.13
For tech guys only :Open right side door, check any obstruction in service station while moving.Check service station connection, re-fix once again.. checkRemove service station, remove motors, clean entire service station with water, ensure that entire ink should be washed out allow it for dry, apply grease to the moving parts, fix it back, check...( cleaning service station is very dirty work be prepare for that). check.. Replace service station...
41helpful
3answers
Service error 5200
I have problem with Canon Pixma IP1500.
System show me ERROR 5200, What means this service error?
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
