Herbatint Permanent Light Golden Blonde 8d Hair Color Logo
e
elle Posted on Mar 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Using 7N and 7C on natural red/blond now growing in grey
To cover increasing grey I mixed equal parts 7N with 7C and had a garish copper red appear! I want to tone this down and cover grey so please can you give me advice? ie ratio of C to N to calm down copper and cover grey??
Victoria Engwall-Rosiello
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 42 Answers
  • Posted on Mar 09, 2014
Expert
Level 2:
New Friend:
Night Owl:
Answers
42
Questions
11
Helped
9953
Points
104
You may have to purchase a hair stripper and recolor your hair.....FIRST though, wash your hair with shampoo 5 times consecutively (wash, rinse, wash, rinse, etc). After the fifth wash, condition and leave on for 5 min then rinse and see if that toned it down. If not, purchase a hair color remover (stripper) and recolor your hair with a more tame shade.
1helpful
If I have natural blonde hair then decide to dye it head in the clouds blue permanent from Garnier, will I be able to return to my natural color r blonde if I don't like it?
If you die your hair,you can either wait for your hair to grow back out(which could take a while) or you can bleach your hair to make it look semi normal so you could have blonde hair again.
Hi...I recently used Goldwell topchic 9N and mixed it equal parts with topchic 30 vol. cream developer. My roots came out a reddish tone which I do not like. My virgin color is between a 2 and a 3 (Dark...
it's only possible to lift 3 shades (like 3to 6, or 4 to 7) without taking undertones into consideration. To go from a dark brown (level 3) to a 9n you would have to pre-lighten your hair with an on the scalp bleach first. Then color with 9n and 20 volume
My sideburns are turning white but unevenly. I want them white. How?
Three solutions to this: you can dye them to match either bleaching the darker side till it's lightest blonde and adding a grey toner (hard to match and quite damaging, use a tone colorant which is a few shades lighter to color the white hair only (looks natural If done properly) while your hair is in that stage. Or shave your head.
I have naturally dirty blonde hair, and about 7 weeks ago I dyed my hair for the first time using a demi permanent 6R medium red brown. The color came out like the little mermaid, and since then it has...
If you have a beauty supply store near you, like Sally's, purchase Roux Fanci Full Styling Mousse in one of the blonde shades to tone down the red. This product works really well and provides a wide variety of colors,
I have natural lt brown hair w/ blonde highlights. I wanted a more uniform color and to get rid of the grey. I bought wella color charm 811/8n light blonde and used 30 volume developer. Left it on the...
Gray hair is resistant to accept color.....You might try to find one of 2 products: " Zotos Porosity Equalizer" from Sally's or any beauty supply store. Also, Clairol has a new formulation called "Gray Solution", where there is a cream added to gray hair prior to adding color. This is for next time you plan to color.
In the meantime, you may want to purchase Roux Fanci-Full Color Styling Mousse in either #19 or #18 to tone down the red tones from your local beauty supply or online.Good Luck
My hair is naturally black but at 44 it is 90% grey. I used the med natural for 10 min and it has brown highlights. Some guys have used the dark ash and said they're hair went reddish something I...
Hello Dear
The Dark natural is the best choice but when your hair grow they are naturally grey or white, the show a great different that look odd sometimes. Try one tone down in darker shades. Ash grey is a good option if that suits you and your complexsion. If you need further assisstance tell me your complexsion tone.
Hope it will help you.
best wishes
regards
NOTE: Please rate the answer if you found it helpful.
I USED 5RR MIXED EQUAL PARTS WITH 5B. WITH BLEACH FOOLS. WHEN RINSED THE RED ATTACHED TO THE BLOND PIECES AND TURNED THEM PINK. NOW HOW SHOULD I GET RID OF THE PINK?
when you bleached your hair you removed all the pigment from your hair which is why your hair turned pink. You need to use a color the same level you want to achieve but make sure it is an N ( to put back the primary colors ) this is called a filler. after you rinse and dry then apply the 5RR . it helps to rinse out not shampoo joico color esp the red series then use joico cuticle sealer. don't shampoo your hair for 2 days , it should help with the red fading. always use a filler when coloring bleached hair.
How much peroxide do i add to koleston perfect 8/00 to put blonde hi lights in red hair
Its equal parts, Make sure you use 40 vol peroxide and you have virgin hair ( No Other Color )
You can't lift color with color you would have to use bleach if you have color on your hair and it hasn't been cut out all the way!
Top Herbatint Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Herbatint Health and Beauty Expert? Answer questions, earn points and help others
