I need to change the input to Game or Video, I'm not sure which. I have a N9278UD Magnavox remote, but I don't know how to program it.
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
SOURCE: How can I input my sylvania 27"
Here are the instructions for the TV.
http://www.sylvaniaconsumerelectronics.com/pdf/om/6427TE.pdf
They do not say how to select Video or Game mode without the remote. Try connecting a vcr or game to the input and do the Channel Pre-Select process to see if that will pick up the input as part of the Channel Scan. If it does you will be able to get to Game or Video using the channel up/down buttons. Another option is to get a replacement universal remote that has a code for your TV and will assign a button for Game or Video.
SOURCE: How did you get the sylvania tv into game mode with out remote
I had to use a dishnetwork remote that I had lying around. You also may able to program a direct tv remote, replaytv remote or universal remote. I have found that putting it into 'game mode' does not work. You will not be able to change the input without a remote.
Here are the instructions for the dishnetwork remote I was using (may differ slightly from yours):
Sylvania Television codes: 733, 506, 525, 536, 566, 568, 569, 573, 600, 610, 652, 654, 656, 659, 660, 664, 665, 666, 671, 672, 674, 677, 723, 724, 729
1. Verify the remote is a DISH Network remote. Look for the DISH Network logo on the bottom of the remote and Mode buttons or lights at the top. Why?
We have the codes for all DISH Network remotes and would be happy to help you with your DISH Network manufactured remote. Please contact the manufacturer of your remote for further assistance. Detailed instructions may be included in the owners' manual that came with your equipment. If not, there may be a toll-free technical support number listed.
2. Look up the Code(s) for the piece of equipment you are trying to address. If the equipment is not listed or a Power Scan is desired click here.
3. Press and hold the correct Mode button (about six seconds) until all mode button backlights come on, then release.
4. Use the number buttons to enter the three digit number (four digit for AUX mode) corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light.
5. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
6. To verify the code works, press the mode button. Then try several different functions for that equipment. Some codes may provide partial function, or respond differently than the button's titled function. Try the other codes listed for that device until you find one that offers more complete functionality.
7. Store the remote code for future use.
8. If the remote still does not operate the device, perform the Power Scan. If still no operation, it may not be compatible with that piece of equipment.
SOURCE: don't know how to change video input without
most tv's have a manual av button.
if not try connecting your video and turn it on / off the tv may automatically select the vidoe.
if not you will need a r/c
SOURCE: how to get TV off game mode without remote (not a
is there a TV/Video or menu button on the front of the tv? if so try the tv/video button, that should scroll through the the components you have on your tv. dvd, game cable etc. If no tv/video, hit the menu button and then use either channel up/down or volume up/down to scroll through your component options.
SOURCE: Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
