I have an older Wingman Digital 3D joystick that I use for helicopter flight simulations. The problem is that the neutralizing spring is too strong for this usage. Is it possible to reduce or even eliminate the spring power? Many thanks in advance for your help.
SOURCE: installed joystick extreme 3d pro wiil not work
Sometimes on those games, if you used a mouse originally, they do not auto-detect that ur using a joystick now - go into the options tell the game ur using a joystick and also there you may be able to set custom control features (what button does what).
Please let us know how it went.
**.The best way to acknowledge contribution is to rate it's relevance.**
SOURCE: Wingman extreme digital 3D Logitech not working on XP
Well you can try download lgs501.exe and run it. This scans on Logitech drivers on your system and can even update them.
( Not checked though, cause I am running on Vista )
My WingMan is an older model with the throttle slider mounted at the center, and there are only 2 buttons on the base. The stick is capable of twist motion (instead of using pedals).
