Televison & Video Logo
Posted on Jun 12, 2009
There is no code search button. how do i program it?
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Jun 19, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
5303
Points
35
Turn on the component you want to program.
  • Step 2 Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on.
  • Step 3 Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
  • Step 4 Release both buttons after the ON-OFF button turns back on. The button should remain illuminated.
  • Step 5 Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off.
  • Step 6 Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again.
  • Step 7 Press and release the STOP button to save the new code.
  • I found this on the internet. hope it helps.
    rhais
    What to use a rca universal remote butdont know the code
    3 Ways to Program an RCA Universal Remote - wikiHow
    www.wikihow.com > ... > TV and Home Audio > Television
    wikiHowJump to Remotes Without "Code Search" Button - Using Brand Code Search ... (for example, many stereos don't support remotes). ... in this article to program the remote,but ... If you know the exact code that you need ...
    Program an RCA Universal Remote Without a "Code Search"
    wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a "code ...Don't let go of the TV button. ... Please tell us everything you know about.
    Programming the RCA RCRN04GR Universal Remote
    How do I program my tv remote
    HI,
    DIRECT CODE ENTRY
    Step 1:Press and hold the "CODE SEARCH" button ("CODE.SRCH" for RCU500).
    Step 2:Press and release the device (VCR, TV, Cable etc.) button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
    Step 3:Enter the 3 digit code number
    Step 4:Release the "CODE SEARCH" button.
    Step 5:With your device on, press another button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test.
    CODE SEARCH
    If you cannot locate the code for your device, try thecode searchmethod below:
    Step 1:Turn on the device.
    Step 2:Press and hold the "CODE SEARCH" button.
    Step 3:Press and release the VCR, TV, Cable or Audio button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
    Step 5:Press "ON/OFF" (or "POWER" for RCU500) repeatedly until the device turns off. Note that because there are so many codes, you may have to press the "ON/OFF" button up to a hundred times (at a rate of once per second) if your code is towards the end of the preprogrammed list.
    Step 6:When your device shuts off, press and release the "ENTER" button.
    Step 7:With your device on, press another button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test, and if it does not function correctly repeat steps 1 through 6.
    CHECK THE LINK FOR CODE
    Electronics Equipment Repair Center RCA UNIVERSAL REMOTE CONTROL 3 DIGIT...
    Electronics Equipment Repair Center RCA UNIVERSAL REMOTE 4 DIGIT CODE FOR...
    Electronics Equipment Repair Center 3 DIGIT RCA UNIVERSAL REMOTE CODE FOR...
    STEPS TO PROGRAM T.V CODE IN UNIVERSAL REMOTE
    For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
    Programming a Device using Code Search:
    1. Manually turn ON your device (TV, VCR, Cable Box)
    2. Press and "HOLD" CODE SEARCH
    3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
    4. Release CODE SEARCH.
    5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
    6. Once the device turns off, press and release ENTER.
    7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
    Programming a device using the Code Lists:
    1. Find codes for each device and brand below.
    2. Press and "HOLD" CODE SEARCH.
    3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
    4. Enter the three digit code from the TV, VCR or Cable Box code lists.
    5. Release CODE SEARCH.
    6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code
    7. You can try using these codes: RCA Codes 000,005,007,008,028, 035,037,054,069
      Hope you find this helpful.
      Thanks ,
      Dennis
    Need code to an rca universl remote to control a magnavox tv
    RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
    The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
    • TV-000
    • VCR-000
    • Cable Box-000
    • AUX is programmed with VCR code 037
    6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
    Magnavox TV Codes: 006, 007, 010, 013, 016
    How do I program the giant universal remote?
    Code Search (HARD)
    1.Hold Code Search button Down
    2.Press and release Device button TV,Vcr,ext....
    3.Press on and off button repedatley until device turns on/off
    (You may have to do this up to 1,000 times)
    Manual Entering (EASY)
    1.Look in instruction booklett or on back of box for a list of device codes
    2.Find your device model code
    3.Hold Code search button
    4.Enter code with # keys
    5.Release Code search button
    3helpful
    2answers
    Need directions 4 rca rcu 800b [rcu800-or rcu403 to program code
    RCA TV Codes: 000,006,011,019,027,034,038,044, 046,088
    RCA Cable Box Codes: 000,027
    Special Notes:
    RCA, GE and Proscan Brand Devices:
    Many of these devices (TV's and VCR's) will not need to be programmed. In the event that programming is required, the code search method is suggested.
    • TV-000
    • VCR-000
    • Cable Box-000
    1helpful
    Need to program a new remote for RCA TV
    • TV-000
    • VCR-000
    • Cable Box-000
    For more info, copy and paste this link in your address bar so you can get codes for you remote:
    http://www.thompsontv.com/rcarc.html
    1helpful
    Need codes
    Unit does not have a manual, but I did find this -
    Let me know if this works, and if not, I'll keep looking.
    7helpful
    3answers
    RCA Universal Remote set to my Emerson TV
    • TV-000
    • VCR-000
    • Cable Box-000
    Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
    Universal remote
    Codes for Samsung (one of them should work on your RCA remote)
    006,011,014,015,019,027,036,037,077
    • TV-000
    • VCR-000
    • Cable Box-000
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
