Question about Kenmore Elite 45986 Front Load Washer
I have a Kenmore 'Elite' front loading washer that stinks
I have a Kenmore 'Elite' front loading washer that produces a 'sewer gas' smell when the first load of wash is run after sitting for a week. I have checked for open drains etc and found nothing that seems to be a source. The smell seems to be coming from the discharge water from the wash cycle. Any suggestions would be welcome.
gsquare-ent@thegibsons.com
  • 19 Answers
The Kenmore Elite Washer has a "large Item filter" located under the steel front panel. This is definitely where your moldy sewer smell is coming from. It traps large items from going down your drain, but they put it behind a metal panel so you wouldn't even know it's there. You need to remove 3 bolts from the front panel, the panel will slide down. You will see a white plastic knob right in the center, push a folded towel underneath the knob then carefully unscrew it. Lots of icky black water will come out. Recognize that smell? You'll probably also find some paperclips and bobby pins and other laundry debris. Remove the filter grating and clean that thing with hot water until it's white again. I squirted some anti-mildew agent inside and let it air out for a few hours, then reassemble and run a Whitest Whites cycle (empty) with some bleach. Smell will be gone. (until next time...)
Posted on Mar 07, 2012
  • 3 Answers
Have you been leaving the door cracked open after washing a load? If not, mildew will form and smell. If you have, then it would be something else. Respond with any questions.
Posted on Jun 21, 2009
6ya staff
SOURCE:
I occasionally have a sewer gas smell near my washer. But after I run the washer, the smell will go away for a few days. What could the problem be?
Hi Joe
Is that pex pipe on the right your water supply to the washer?
Your sewer gas smell I believe can be eliminated by putting a P trap in the drain PVC line.
(EDIT)
Where the drain hose from the washer hooks into the PVC pipe is NOT airtight which would allow the sewer gas back into the laundry room!
(EDIT EDIT)
If there is a P-trap in your outflow pipe, the only place left for grey water to collect (and stink) would be between the washer and where the waste hose goes into the drain. We've had to use a little bit of bleach on occasion when we haven't used the washer for a bit.
Hope this helps
-Steve
May 02, 2015 | Maytag Neptune Washing Machines
Help, my dryer stinks like sewer smell when running, my husband just vacuumed out all of the vents, and it still smells foul!
This is common for front loader washers. They make cleaner that you run through your washer once or twice a year to correct this problem. Take a look at this page there is a link to where you can buy some of the cleaner under the section called clean washer http://www.appliance-repair-it.com/dryer-maintenance.html
Oct 05, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My Kenmore Elite smells like mold!
Run a cycle ,no clothes in, with about 3 cups/ 750 ml of bleach in it. How? put a fil a plisticbag with the bleach and set it in the washer. It will tip up when you start the cycle. You should end up with a clean washer and clean empty bag.
Jun 27, 2010 | Kenmore Elite 45986 Front Load Washer
Strong mildew smell in washer is making cloths & towels smell bad, how do you get rid of the problem?
if you look inside washer there is a rubber rim on the inside around the openning. Look inside and you will find where the stink is coming from. Keep door open when not in use and wipe inside of rubber trim to keep the mildew out.
I use tilex sometimes and do a rinse spin.
Nov 16, 2009 | Kenmore Elite 45986 Front Load Washer
Laundry room smells like rotten eggs
Does the sewer drain line have a trap at the bottom that prevents sewer gas from entering the room? If the smell seems to be coming from the washer itself, run a wash cycle empty with a cup of baking soda, detergent and hot water to clean the interior.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stinky clothes
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Aug 17, 2008 | Kenmore Elite 45986 Front Load Washer
Stinky Washer
We had the same problem with our front loader. (after only a year) We ran a load on "sanitary" setting with bleach. After that we leave the door open after EVERY load. That has fixed our problem
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore Elite 45986 Front Load Washer Logo
671 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
