A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Drain the fryer. Cleaning the kettle will make things easier. Remove the thermostat knob and remove the two screws that hold the thermostat. Remove the two wires. Under the kettle you will see a double headed bolt with a tiny stainless tube running through them. Make sure that you do no confuse the one for the thermostat with the one for the high limit. Loosen or completely unscrew the small inner nut. Unscrew the large outer nut. Inside the kettle, locate the sensor bulb that corresponds to the thermostat. Remove the bracket and vertically straighten the sensor bulb. From under the kettle pull the sensor bulb and wire down and remove thermostat. Clean the fitting where you removed the bulb. Replace with new thermostat in reverse order. Avoid sharp bends in the sensor wire. Use Teflon tape on the large nut. The small nut is a compression fitting and does not need Teflon tape. Reclamp the sensor bulb and pull excess tubing from the kettle before tightening the small nut. Be careful not to cross thread the nuts. Do not over tighten the small nut. Refill the fryer and check for leaks.
Make sure that the gasket is put in right. If put in wrong, it can keep the thermostat from opening. Also make sure that you put the thermostat in the right. The sensor coil or slug goes toward the engine. The thermostat should be stamped showing the proper direction. I would go ahead and buy a new one just to be sure. They are cheap.
try this link http://www.vendingmachinesworldwide.com/gold-medal-2014-***-90s-whiz-bang-popcorn-machine-kettle-receptacle-replacement-part-gm49330.aspx
hope this helps if its not the part you require email them , there really good VendingMachinesWorldwide.com, Worldwide Markets, LLC 2630 Ladue Cove Fort Wayne, IN 46804 Email us for all inquiries
The problem you are having is the thermostat inside the kettle is getting weak these can be ordered from Star Manufacturing or a concessions supply place that does repairs Also Gold Medal Product has a similar thermostat that will work in your kettle pt# 47082 Just a FYI
