General error in r290
he maintenance request error is actually a Waste Ink Ink Pad Error and usually your remedy is to replace the Waste Ink Pad/Pads with a new one/ones and then reset the Internal Waste Ink Pad Counter. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer. You can see "Exploded Parts Diagrams" of most Epson Ink Jet Printers and can also check on possible parts ordering, by Compass Micro Inc, at http://www.compassmicro.com/parts_select.cfm . Some people actually wash the ink out of the old pads, by holding them under running cold water. Then they simply dry them out and reinstall them back into their printer.
The choice on what to actually do, is yours to make. I would at least recommend getting that Waste Ink Counter reset procedure and performing it first, to make sure your printer will then work. There is an "Epson Stylus C60 Printer Information Page", that also includes the C43 series, that you can view at http://epsonhelp.freehttp.com/C60.html .
It does have a section on the left side you can click-on, titled WASTE INK PAD SERVICING and also a section titled HOUSING REMOVAL, that will be of some help to you, if you want to try the needed servicing. However, you will still need to go on-line and buy and download the actual Reset Procedure, to clear the actual Service Error Condition, if the SSC Service Utility listed below does not actually work on your model of epson printer and your computers operating system...THIS ADDITIONAL INFO MIGHT ALSO BE OF SOME HELP: Tim H 12/10/2003 2:46:24 Subject: Epson Reset Program Download Location. after a long search for a reset program for waste ink, without paying, i found it. goto: http://inkjetprinterhelp.us/sscserve.exe . please check that your printer is compatible goto: http://inkjetprinterhelp.us/epsonSSC.html .
this program has other features as well...Here's some previously posted info by NEWUSER, on that SSC Utility: Re: Epson C40+ Error and power light flashing by newuser (4/5/05 11:10 AM). To reset the error download this utility:
http://inkjetprinterhelp.us/epsonSSC.html . Once installed run the program and configure it, closing the main window and right clicking the icon in the tray area, from there choose Configure and select your printers model. After configuration, select Protection counter -> Reset protection counter, it should be able to clear the error message. If that does not actually work, then the only suggestion I can give is to perform a soft-reset before resetting counter.
Remove also the Epson status agent, it detects errors and it may hinder communication with the printer, then reboot your pc. As profile choose the one sscservice didn't use after autoconfiguration, check for printer response. Remember that you should also clean the waste ink pads located at the printer bottom, for a step by step guide download the service manual for your printer from this site
Unfortunatly, that "SSC Service Utility" does not work on all Epson Printers and not on all Operating Systems and sometimes will not even work on actually listed printer models, so you will have to check it out for yourself. Just in case that source does not work: You may actually need to go on-line to try and locate a "SERVICE MANUAL" and or the actual "RESET PROCEDURE", to buy and download for reference in disassembly, troubleshooting and servicing. I have not checked, but you can normally find Service Manuals & Reset Procedures for most Epson Printers
