SOURCE: My 2004 chevy impala power
If the buzzing is sound is coming from the doors, then the motors are going bad. If the buzzing sounds like it's from under the hood, then check the relay switch and see if it went bad and needs to be replaced.
SOURCE: My windows will not go
It can be window motor.All the windows have their separate motor.Before ordering the motor, check with any of the other motor first.If the motor gets weak. Then it will make such noises while moving the window up or down.If switch i replaced, then most probably its faulty motor.
------------------ Hope this helps.Thank you.
