PEAK 450 Plus Portable Power System Logo
Johnny Prince Posted on Mar 08, 2014
AIR COMPRESSER COMES ON BUT NO AIR COMES OUT ALMOST LIKE IT IS CLOGGED
Gerald Atkins
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 08, 2015
Gerald Atkins
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
264
Points
The motor that drives the compressor is fine. I think you will find that the compressor itself is kaput. This was true in my case.
Air compressor wont produce more than 60psi
clean the one way cheak valve on the head of the air compresser motor whier the big line comes out and goes to the tank.
Its not getting cold
if it is comes on but not cooling then look and see if the compresser comes on if not it can be bad or a bad run cap or low on ref might also be a hi presses button
Compresser overheat triping
Hi!!
It could be a few things that make the compressor overheat, when this happens, the bimetal thermal protector shuts it off to avoid damage to the unit.
Some of the reasons could be:
Dirty condenser and/or evaporator (if condenser is dirty or clogged up, the heat absorbed by the evaporator will not be dissipated, this will cause the compressor to overheat.)
Bad fan motor.(not blowing enough air to cool down condenser).
Bad capacitor (only if compressor fails to start right up or not at all.)
Worn coils inside compressor.
System clogged or dirty. (If the system is dirty or clogged up, the compressor's workload increases causing it to overheat.
Don't forget to rate this post, Good Luck!!
1helpful
Air conditioner does not blow cold air
so many different possibles of this problem impossible to tell you exacty what your problem is without doing some test on it
so possibles are
low charge
bad clutch
bad compresser
clogged orvice tube
bad low pressure senser
bad high pressure senser
bad blend door
fuses
relays
evaportor
condesenser
The air conditioner cooled on the driver's side and heated on the passenger's side. Took it to the place where they replaced a new gm compresser 2 years ago and they tested and stated that it is an...
If the compressor cycles on and off very fast, you most likely are low on coolant and it needs recharged.
The cigarette lighter light is not on the same line as the lighter itself. Check your fuses.
You could have a problem with the damper in the vent system, giving you different temperatures on either side of the vehicle.
My mother's 2002 ford taurus has no heat. When
yes there is a blend air door that mixes a/c with the heated air and it sounds like it is out of adjustment the other thing is the heater core could be plugged
5helpful
2answers
AC compresser throws breaker
It could be a few things..
Might be the compressor going out ;o(
But could be the capacitor..
Its about a 4 inch part with 3 wire conectors at the top.. Could be round or oval and is usually metal & looks like a can..
This part replacement fixes problems in allot of cases & shouldnt cost to much.. If it is not the problem - at leaste that part is eliminated... Good luck..
Top PEAK Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a PEAK Computer and Internet Expert? Answer questions, earn points and help others
