http://teral.ru/katalog_stiral_nyh_mashin/siemens_simens/?p=6
use google translate
Malfunction of the water of the Gulf ( the Gulf of spent more time than envisaged by the program ) .
lol
so your water intake is too low a preasure
try too use low pressure valves for cold water
if you have low pressure
then use the hot water valve in the cold water
cold water valves are like 2-3 bar intake
hot water 1 bar or less
so work better for low pressures intakes
or there is a flow filter on the back of valves
you need to remove it with plyers and clean it
moreover check the valve opens
but this is what F17 means... no water in in the right time for it too be in {low pressure}
good luck
