Question about Mach Speed Speed Tablet Trio Stealth G2 7" Display w/ Ice Cream Sandwich Black
Trio tablet wont turn on
Tablet wont turn on can charge it and wont turn on know that charger works as it powers the other tablet tried pressing reset button noticed faint red light came on in charging port hole after pressing reset let it sit for 20 min and tried turning it back on nothing
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Sounds like the hard drive is froze up
Posted on Mar 08, 2014
6ya staff
SOURCE:
My tablet was working fine the next day I went to use it I turned on it wont go past trio@9dualcore
if other solution fails, you can do a hard reset.
follow this procedure.
1. switch the tab off. after,
2. long press power button +
volume down key simultaneously.
3. after it shows the logo then
release the power button but
continue pressing the volume key
until the wipe or reset menu
appears.
try it, it works and start thngz afresh
Apr 04, 2015 | Mach Speed Trio Stealth G2 Tablet -...
Trio Quad Core Tablet will not charge
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
Jan 01, 2015 | I-INC UniK Trio AXS 3G with Wifi 7.85"...
My RCA tablet is charged but it won't turn on.
If it wont turn on how do you know it is charged ?. Are you sure the charger is working ?. connect the charger does the tablet show it charging ?. Over time I have replaced many faulty chargers .
Dec 27, 2014 | Tablets & eReaders
How to fix trio stealth g2 stuck on boot ?
turn it off. if you can't then their is a reset button on the side where the charger is. Get a safety pin put it in the hole. You will know if you reset it. It will reboot. It won't effect your files or info. I hope this helps!
Jul 01, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Why my trio stealth g2 wont turn on
If it isn't charged it will not turn on.
Make sure the charger is working. Use an AC/USB charger.
Other than that it's broken.
Use the extended warranty you purchased when you bought the tablet.
May 03, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Mar 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
My trio wont work!
try your charger with some other device
if its working then there is a problem with your charging ic
or processor
go to othorize service centre
Feb 01, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
Charge trio g2
Hi Jennifer,
Battery error or charger error.try with new charger or usb cable.
if you have warranty you have no problem and go for warranty.
regards.
nuwan
Jan 10, 2014 | Mach Speed Trio Tablets & eReaders
My trio stealth g2 7" tablet wont turn on
Check for a bad battery, charger in that order.
Each can be gotten inexpensively on ebay. eBayeBay
Sep 04, 2017 | Trio Stealth G2 7 inch Tablet with 8GB...
Mach Speed Speed Tablet Trio Stealth G2 7" Display w/ Ice Cream Sandwich Black Logo
816 people viewed this question
Top Mach Speed Tablets & eReaders Experts
 Mike M
Mike M
yobo007
yobo007
Are you a Mach Speed Tablet and eReader Expert? Answer questions, earn points and help others
