Directly in Zebra, press Setup and 6 time the - .
You see Ip adress, gateway etc...
The IP address can be manually change in the printer panel. It may ask for a password, and the default password is 1234.
If the printer is a network printer, you can install the zebranet view from the CD provided and change the configuration according to the requirement with the zebranet view.
As mention in my previous answer, the IP address can be change manually in the printer panel. When acessing the Printer Panel it may ask for a password, and the default password is 1234. After modification, save it as PERMANENT.
I normally do it through the network connection. If the printer is a network printer, you can install the zebranet view from the CD provided to your workstation and change the configuration according to the requirement with the zebranet view
SOURCE: How do I change the IP address on my zebra zm400.
Whilst looking at the menu where the IP address is, press select. It will ask for the password which is 1234, this can be input by using the + and - keys, + changes the number by press and - moves the field. You should be able to change the IP address.
SOURCE: como cambiar ip de zebra zm400 desde el panel
you need to connect with some network to the ip adress coming on the setings, if you dont connect with network, that function not apper.
If connect, you be aple to change to IP estactic and the Gateway and the subnet mask.
Dont forget to save.
SOURCE: Why the IP address cannot
I have the same problem before, but i change the IP through Zebranet view tools.You can install the zebranet view from the CD provided to your workstation and change the configuration according to the requirement with the zebranet view
Press on setup button
Press on the - button
until you see protocol
Press on select and
choose permanent and save
Press on the + button
until see the IP Address
Press on select and use
the + button to change numbers and Press the - button to move to the next
number.
Press selects to save
restart the printer by switching the printer on and off.
Test a print job to the Printer.
