Question about Zhone (6218-I2-200) Router
WPA group re-key interval - Zhone (6218-I2-200) Router
How to config to work wireless
bridge irb
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 45
encryption vlan 1 mode ciphers tkip
ssid cisco
vlan 1
authentication open
wpa-psk ascii 0 cisco123
authentication key-management wpa
ssid ciscowep
vlan 2
authentication open
ssid ciscowpa
vlan 3
authentication open
Step 5 bridge-group number
Example:
Router(config-subif)# bridge-group 1
Assigns a bridge group to the subinterface.
Note When the bridge-group command is
enabled, the following commands are
automatically enabled, and cannot be
disabled. If you disable these commands
you may experience an interruption in
wireless device communication.
bridge-group 1
subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1
block-unknown-source
May 21, 2013 | Cisco 878 GSHDSL Wireless Router for Small...
WAP/WEP password not working
These are the two options for your Router. Don't forget to save your settings
WPA is an upgrade to the WEP (Wired Equivalent Privacy) standard for securing your wireless network. If you would like to secure your wireless network using WPA, you will need the following:
  • WPA enabled on your Dell TrueMobile 2300 Wireless Broadband Router
  • WPA support for your wireless clients. If you are using a Dell TrueMobile wireless client, you can check for the availability of WPA enabled software update for your wireless client at http://support.dell.com.
  1. Log into the Web configuration of your router at http://my.router (or the default address http://192.168.2.1)
  2. Click on Basic Settings.
  3. Click on Wireless Security.
  4. Click on the Enable Wireless Security checkbox.
  5. Select either WEP or WPA in the Network Authentication list.
To setup WPA
  1. Enter your pre-shared key. This key must match the key that is used by each wireless client computer associated to your router.
  2. Choose a key format. This can be hexadecimal digits (0-9, A-F) or ASCII characters (any key on the keyboard).
  3. WPA Group Rekey Interval specifies how often the key rotates or changes.
  4. WPA Encryption allows you to select 1 of 2 possible encryption methods (TKIP and AES) - choose one that your wireless clients supports.
  5. Click NEXT, then Save and Restart to apply the changes.
  6. Setup the WPA on your wireless clients. Refer to the documentation that accompanied your wireless clients, or your wireless clients on-line help system for information on how to setup WPA.
May 14, 2012 | Dell TrueMobile 2300 Wireless Broadband...
I've been trying to play a game online recently (Battlefield Bad Company 2), and whenever I'm playing it I lose connection. I've also been getting "content encoding errors" on...
Check out page 39 of the user manual or click here http://www.manualowl.com/m/D-Link/DIR-632/Manual/156044?page=39
Different games have different settings so I'm not 100% which configuration you will need.
Also, if you navigate to the configuration setup by opening a web browser and entering the IP address of the router (ie:192.168.0.1). Click on.Setup.and then click.Wireless.Settings on the left side. 2. 3. 4. 5. 6. 7. Next to Security Mode, select WPA-Enterprise. Next to WPA Mode, select Auto, WPA2.Only, or.WPA.Only. Use ... Key Update Interval, enter the amount of time before the group key used for broadcast and multicast data is changed (3600 is default). Next to Authentication Timeout, enter the amount of time before a client is required to re-authenticate (60 minutes is default).
Hope this helps :D
Sep 21, 2011 | D-Link (R) DIR632 WirelessN 8Port Router
Lost password for my dlink and trying t add the i pad
Hi
You can login to the router setup by typing http://192.168.0.1on the address bar of Internet Explorer
Make sure you do it on a computer that is connected to the router with a Cable
Then enter the default password (admin) lo log in to router settings
On the left side Click Wireless Settings
Here you can see
Wi Fi Protected Setup Also known as WCN in Windows Vista
Disable it
The Next section Will be Wireless Settings , you can find the name of your wireless network here
Change it to a different name
Make Sure the Visibility Status is set to VISIBLE
On the next section you can find the Wireless Security Mode
Make it as WPA - Personal
Then Choose the WPA Mode As WPA Only
The Cipher Type should be TKIP and AES
and the Group Key Update interval should be 3600 Seconds
Then in the Pre Shared Key box ,
Type A Password
It Should be Minimum 8 Characters
Make Sure you remember the New Name and the Password
Click Save Settings at the top
Now the Network is ready
Try to lookup this network on the Ipad
Connect
When prompts for password
enter the new Password
Let Me Know if it works
Regards
TOM
Aug 17, 2011 | D-Link (R) DIR601 WirelessN 150 Router
Need to set up a pass word on my router
Click the below link
http://192.168.1.1
Now it will ask for username and password
Enter username = ( blank) and password = admin
If you can't login using this credentials then you will have to reset the router
If you logged in . Then click on Wireless > Wireless security
On this screen select
Security Mode : WPA Personal
WPA Algorithm : TKIP
WPA shard Key : "enter a password here"
Group Key Renewal : set to default
Click on save settings. After that restart router .
Now your wireless network is secured and you will have to type the WPA shared key inorder to connect to router when it prompts
Thanks
Vote me If it helps
Feb 01, 2011 | Linksys Wireless-G WRT54GS Router...
What is a wpa passphrase
The WPA passphrase is the wireless router's encryption key. The encryption key is generated using a phrase which is used to generate a group of hexadecimal numbers.
Dec 28, 2010 | Office Equipment & Supplies
How do I find my wpa2 key on D-Link DIR-655?
  1. If Donna's method didn't work you can try this. Just an additional thing.
  2. First of all you have to Open your Browser
  3. Type http://192.168.0.1 (or use the NetBIOS name http://dlinkrouter)
  4. Log in.
  5. In the router setup page click on wireless settings
    then click on Wireless Security. It has to be there. Check under the Advanced Tab if its not there. You will be able to Enable/Disable WPA/WPA2 with PSK. Check whether you can see it there (the Key).
  6. If it allows you to re configure you have to go through the Setup partially again (look below). If it doesn't allow and you can't remember the key, you have to Reset the Router and go through the Full Setup.
  7. Here is how:
  8. Under the Wireless settings Wizard, Click on "Launch Wireless Security Setup Wizard".
  9. Click "Next".
  10. Enter the SSID which is the Name of your Wireless Network (Case Sensitive).
  11. Choose the Level of Security. Click "Next".
  12. If you have chosen "Best" or "Better", enter a key which is 8-63 long. If you selected "Good", enter 13 Characters or 26 HEX Digits. Please Write it down.
  13. Click Next. If you have chosen "Best" or "Better" you will be shown the key in the next Window.
  14. If you plan to use WPA-PSK encryption, you can configure that as well.
  15. Next to Security Mode, select WPA-Personal.
  16. Next to WPA Mode, select Auto, WPA2 Only, or WPA Only. Use Auto if you have wireless clients using both WPA and WPA2.
  17. Next to Group Key Update Interval, enter the amount of time before the group key used for broadcast and multicast data is changed (3600 is default).
  18. Next to Pre-Shared Key, enter a key (passphrase). The key is entered as a pass-phrase in ASCII format at both ends of the wireless connection. The pass-phrase must be between 8-63 characters.
  19. Click Save Settings to save your settings. If you are configuring the router with a wireless adapter, you will lose connectivity until you enable WPA-PSK on your adapter and enter the same passphrase as you did on the router.
Jun 13, 2010 | D-Link DIR-655 Wireless Router
Hi there, i just had telstra install a Cisco 857w router. i am trying to setup the wrieless and am having no luck, i am not very computer literate so i may need to explained in very simple...
Need to setup the wireless on your 877W or 857w. use the following sample.. obviously update the SSID and wpa-psk key.
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
no ip address
bridge-group 1
no shut
broadcast-key change 60
encryption mode ciphers tkip
ssid MYSSID
max-associations 10
authentication open
no guest-mode
wpa-psk ascii mywpapskpwd
world-mode dot11d country AU outdoor
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2452
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip virtual-reassembly
ip tcp adjust-mss 1400
bridge-group 1
hold-queue 100 out
interface BVI1
ip address 10.0.0.3 255.255.255.0
ip nat inside
Jun 09, 2009 | Computers & Internet
I am attempting to secure my network through this router which at this time is open for the whole neighborhood to see
Here are the diffenent types of Security Settings possible with a wireless router: (how to set this depends on the brand of router)
Security Mode: You may choose from Disable, WEP, WPA-Personal, WPA2-Personal, WPA-Enterprise, WPA2-Enterprise, or RADIUS. All devices on your network must use the same security mode in order to communicate.
Capture(wlansec.wpapersharekey) WPA Personal:
Capture(helpwpa.phase8) WPA Algorithm: You may choose from TKIP or AES.
Capture(helpwpa.phase9) WPA Pre-Shared Key: Choose a unique key to authenticate with other devices on your network. The Pre-Shared Key must be between 8 and 63 characters in length.
Capture(helpwpa.phase10) Group Key Renewal: This settings determines how often your group key changes.
Capture(wlansec.wpa2persharekey) WPA2 Personal:
Capture(helpwpa.phase11) WPA2 Algorithm: You may choose from AES or TKIP+AES. Choose TKIP+AES if you have both WPA and WPA2 devices on your network.
Capture(helpwpa.phase12) WPA2 Pre-Shared Key: Choose a unique key to authenticate with other devices on your network. The Pre-Shared Key must be between 8 and 63 characters in length.
Capture(helpwpa.phase13) Group Key Renewal: This settings determines how often your group key changes.
Capture(wlansec.wparadius) WPA Enterprise:
Capture(helpwpa.phase14) WPA Algorithm: You may choose from TKIP or AES.
Capture(helpwpa.phase15) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase16) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase17) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase18) Key Renewal Timeout: Determines how often your keys should be renewed.
Capture(wlansec.wpa2radius) WPA2 Enterprise:
Capture(helpwpa.phase19) WPA2 Algorithm: You may choose from AES or TKIP+AES. Choose TKIP+AES if you have both WPA and WPA2 devices on your network.
Capture(helpwpa.phase20) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase21) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase22) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase23) Key Renewal Timeout: Determines how often your keys should be renewed.
Capture(wlansec.wep) WEP:
Capture(helpwpa.phase24) Default Transmit Key: The key you would like to use for transmitting WEP keys.
Capture(helpwpa.phase25) WEP Key Bit: You may select from 64-Bit or 128-Bit encryption.
Capture(helpwpa.phase26) Passphrase: You may enter a passphrase consisting of any keyboard character to be used to generate a hex WEP key. Passphrase option is only supported when you are only using Linksys devices on your network.
Capture(helpwpa.phase27) Key 1-4: You may enter a WEP key manually. You must use only hex characters (0-9 and A-F). 64-Bit WEP requires 10 hex characters. 128-Bit WEP requires the use of 26 hex characters.
Capture(wlansec.radius) RADIUS:
Capture(helpwpa.phase28) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase29) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase30) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase31) Default Transmit Key: The key you would like to use for transmitting WEP keys.
Capture(helpwpa.phase32) WEP Key Bit: You may select from 64-Bit or 128-Bit encryption.
Capture(helpwpa.phase33) Passphrase: You may enter a passphrase consisting of any keyboard character to be used to generate a hex WEP key. Passphrase option is only supported when you are only using Linksys devices on your network.
Capture(helpwpa.phase34) Key 1-4: You may enter a WEP key manually. You must use only hex characters (0-9 and A-F). 64-Bit WEP requires 10 hex characters. 128-Bit WEP requires the use of 26 hex characters.
Jul 03, 2008 | Computers & Internet
Secure network
- access your web user interface by typing http://my.router (or the default address http://192.168.2.1) on the address bar of your web browser
- click on Basic Settings
- click on Wireless Security
- click on the Enable Wireless Security checkbox
- select either WEP or WPA in the Network Authentication list (Note: make sure that your wireless computers can support wpa if you're planning to use wpa. wpa is more secured than wep)
if you're going to setup wep, follow the steps below:
- select hexadecimal or ASCII characters as the Key Format, you can use either as a string of hexadecimal digits (character 0 ~ 9 and A ~F ) or as ASCII characters (any key on the keyboard)
- then select your desired encryption level from the Key Length list. it could be either 40(64)-bit or 104(128)-bit key length.
- enter four different keys in the Key1, Key2, Key3, and Key4 fields to store on your router.for 40(64)-bit encryption, enter a 5-character (or 10 hexadecimal digits).for 104(128)-bit encryption, enter a 13-character (or 26 hexadecimal digits) WEP key (note: you'll just need to enter the characters that you've setup on Key1 for all the wireless computers that you have
- click NEXT, then Save and Restart to apply the changes
if you're planning to enable wpa, follow the steps below:
- enter your pre-shared key. this key must match the key that is used by each wireless client computer associated to your router.
- choose a key format. this can be hexadecimal digits (0-9, A-F) or ASCII characters (any key on the keyboard)
- WPA Group Rekey Interval specifies how often the key "rotates" or changes
- WPA Encryption allows you to select 1 of 2 possible encryption methods (TKIP and AES) - choose one that your wireless clients supports
then connect your wireless computers to your wireless signal using the correct wireless security (network key)
hope this'll help you.
Jun 08, 2008 | Dell TrueMobile 2300 Wireless Router...
Zhone (6218-I2-200) Router Logo
108 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
