Question about LG 42LH40 LCD TV
HDMI cords produce video but no audio. LG 42LH40 LCD TV
AV INPUT with the three colored cords work fine, but none of the four HDMI outlets give sound. Video is fine. Worked without any troubles, then one outlet had no audio, and now none of them do. I am afraid to touch ANYTHING! Please help!
Anonymous
SOURCE:
Anonymous
SOURCE: hooking up PS2 to Component hookups on 37" LG LCD
I have an older ps2 hooked up with componant cables too. Dis you buyt the special playstation componant cable?? If so, Make sure the right wires are in the right ports?? does it work with just the yellow cable in the Video??
Posted on Jan 16, 2008
Anonymous
  • 7 Answers
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
Posted on Aug 05, 2009
khal75
  • 3 Answers
SOURCE: only av input is working LG 42LC7D TV
I may put money that some one did stole your internal cable from the power supply to the main board !
Don't be surprised they did it to me at LG company .
Posted on Nov 15, 2010
jdvillanueva
Jdvillanueva
  • 2098 Answers
SOURCE: power will not turn on.
Please let me know if the unit has a led light lit at the front panel or totally dead set. It will help diagnose where the fault came from.
Jdvillanueva
Posted on Jul 11, 2011
mohit
SOURCE: Issues with LG 26LE5300 26 in HDTV LCD TV Both
I tried this.. and it works perfect for the video.. but there is no audio.
Is there any specific setting to be made in TV or my laptop?
I have Dell laptop with Win7, because I dont see any option to enable audio..
Posted on Jan 19, 2013
No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Over-the-air HDTV from the Antenna is perfect audio & video
HDMI Input Problems - TV Not Showing Image - TV Repair ...
? 2:34
https://www.youtube.com/watch?v=ZtaUPX1tHP0
May 26, 2015 - Uploaded by ShopJimmy.com
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
no signal? -hdmi - LG 55LE5400 tv - Forums - CNET
www.cnet.com > Forums > LG
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
No sound on LCD TV - Desktop HDMI connection [Solved] - CCM
ccm.net > Forum > Hardware
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
HDMI vs Component ' TVBlanket
Feb 03, 2016 | RCA Televison & Video
Suddenly, all three HDMI Ports won't receive a signal. Help!
Hi James,
The main board of your TV is not accepting HDMI input. You can use another AV input to watch the TV or you have to change the main board.
Aug 04, 2015 | LG 42LG30 42 in. LCD HDTV
When i connect my pc to my monitor (LG w2353v-pf) via a HDMI cable the monitor tells me to check signal cable. I know my HDMI cable is fine since i have tested it on my TV. also i know that my computer...
Hi raposo69 ,
I see that you are having an error check signal cable.
Have you tried selecting the correct Input for the LG LCD monitor?
make sure that the Correct Input is selected properly to be able to detect the signal from the HDMI cable that you are using.
The audio will not confuse the video on an HDMI Video will be detected as long as the Input on the LCD monitor is selected.
Audio on the HDMI will only work if the HDMI driver is provided like on a desktop computer you will need to get the driver for the HDMI for Audio and video to come out using an HDMI cable but never will audio conflict to the HDMI video output.
I hope this hepls.
Have a nice day,
mvincentc
Apr 13, 2011 | LG W2353V-PF 23' LCD Monitor
I cant hook it up to the tv
Run a three color AV cord (red, white, yellow) from the output of your surround sound receiver to the "DVD" input on your TV. The yellow is for video and the red and white are for audio so make sure you plug the tips into the same color ports. Now look at where you put the 3 color cord (AV cord) into the TV, which "input" did you use? Video 1 or Video 2 more than likely. Now turn your TV on and in the menu settings select the same video input you hooked the AV cords into on the back of your TV. This will get your theater set up. The remote is slow to process after you push buttons so give the remote a few seconds to respond.
Mar 22, 2011 | Protron PDS-2315 Theater System
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
I have picture but no sound LG flatron TV and Pioneer DVD player.
connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
i.e AV1 or AV2 or AV3
Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
Lg 42' lcd cant get video signal i can get sound and menu pictures all come up. but no output from cable or ps3
I guess your either using the scart socket or the HDMI socket. You have gone into the menu and changed your input source to either HDMI or Scart havent you? Does your TV aerial input work when switched to Antenna on the input source menu. If these dont happen then you have a faulty main pcb.
Feb 13, 2010 | LG 42LH40 LCD TV
I cannot get my Sony SF2000 stereo to play through my LG 42lh40 TV in TV Mode...it works through the Blueray however...i've tried the suggested phone jack to 1/8" headphone adapter but it is not working,...
TRY TO RUN COLORED AV COMPONENT CABLES FROM THE STEREO TO THE TVS HEADSET JACK. IF COMPATIBLE? THIS IS THE STANDARD AUDIO CONNECTION FOR HOME THEATRE SYSTEMS.
Dec 14, 2009 | LG 42LH40 LCD TV
LG tv shows av inputs as black & white
you need to plug all three colors in not just yellow
red blue green need to be pluged in their respective colors
Nov 28, 2009 | LG 27LC2R 27 in. LCD TV
LG 42LH40 LCD TV Logo
116 people viewed this question
Ekse
RONALD CARTER JR
