Question about Westinghouse SK-32H240S Television
Video goes out after approx. 30 sec
The unit powers up and all works for about 30 seconds. Then thye video goes out but audio continues to work. This is through all inputs that I have been able to try (cable, RCA, VGA and S-video)
  • 10,594 Answers
HI,
Question title shows you have Westinghous SK-32H240S LCD TV, if its correct...
Problem seems with back light inverter board. You can confirm it as when screen becomes blank / dark, point flash light / torch on screen and try to see faint image. If that faint image is there then its back light board inverter problem and that board requires replacement.
Let me know the results to move further or if it is different model and brand TV, please intimate its details.
Thanks.
Posted on Jun 13, 2009
6ya staff
SOURCE:
Sansui 7070 receiver Hum
Your filter capacitors in the power supply section are to blame and they need to be replaced.
Mar 30, 2014 | Sansui 221 Amplifier / Reciever
Mitsubishi tv ws55613
The steady blinking light means there is no specific code.
Apr 23, 2008 | Televison & Video
No power on (LCD27TV006HD)
Does the standby light continue to blink? IF so, count the number of blinks and go to:
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
That may help you decide what is going on.
In the long run you will probably need to have a tech take a look at it. The problem you describe is usually a serious matter that needs repair by a trained technician..
Goodluck,
Don't forget to rate me as fixya...
Feb 03, 2008 | Televison & Video
How do I add an extra camera to this monitor?
I had the same problem, but just figured it out! The Instructions that come with the camera are wrong (obviously).
So instead of holding down just the "video on/off" button for 2 seconds...Hold down the power button AND the "video on/off button together for 2 seconds.
Then the power led will flash amber and you can hit the code button on the camera and it will work!
Jun 30, 2010 | Summer Infant Slim Secure Handheld Video...
Hdmi doesn't work
Make sure everything is pluged in correctly and the Playstation 3 is on stand-by. The using the power button on the console hold it for about 5 seconds till you hear two beeps. And this will reset the display settings.
Don't hold it to long or it will go on stand-by.
Also try reversing the ends of the HDMI
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
Liquid Video monitor goes black after 30 seconds
Capacitors on the power board inside the lcd monitor have blown they can be replaced with new ones and the monitor should return to normal operation.
service center or if you feel capable you can do it your self with a soldering iron and the correct caps that have blown you need voltage and micro faradays usually 25 v at 470 mfd (u)however monitors use different kinds and voltages can be different it will be marked on the side of the damaged capacitors.
l8r
Nov 11, 2008 | Computers & Internet
Protector flashing on unit
Push the power button when its off and the A and B speakers buttons at the same time for 30 sec. wright back to let me know how it goes..ok
Aug 31, 2008 | Sony STR-DE625
Picture and sound cuts off ,greem stb light keeps blinking TV turns on after 30 secs shuts off after 30 secs comes back on. Continious loop
How many blinks do you get? Depending on the amount of blinks you can figure out what the issue is.
If it blinks 6 times you can get the fix at
No power RED Standby LED flashes 6 times/KDF55XS955, KDF60XS955, KDFE55A20, KDFE60A20
They have other fixes for E60A20
http://www.agoraquest.com/viewtopic.php?topic=31806&forum=70&keyword2=electronics
Dec 28, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Denon avr 3000
Anyone want to buy a working Denon AVR-300?
hdurity@comcast.net
Dec 01, 2007 | Denon AVR-2106 Receiver
Televison & Video Logo
281 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
