Four reasons come to mind that may prevent you from connecting:
Wi-Fi Passwords are case sensitive. Please check again if you entered the password with proper casing and you did not put any extra white space in front or behind. I know, this sounds annoying, but it is really the most common cause for connection problems.
Give your network a unique SSID. This is the network name that shows up in the list of detected networks. Default names like LINKSYS can be troublesome if a neighbor one block down the street happens to have a router from the same company.
Some routers have a MAC address filter as a security measure, limiting service to devices specifically whitelisted. If your router is set up for this, add your Kindle's MAC address to the list of permitted devices. See your router's configuration under Wireless > Wireless MAC Filter. You can check the MAC of your Kindle from its settings page (press HOME, MENU, select SETTINGS, see paragraph headlined "Device Info".
There are twelve different standards for Wi-Fi transmission collected under the hood IEEE 802.11. The four most dominant transmission modes are called a, b, g and n. They differ in radio frequency, modulation method and data rate. Kindle supports the two standards IEEE 802.11 b and g only, which is not really a problem because all wireless routers I ever encountered support one or both of these, too. However, the Linksys N-series can be set up to use 802.11n exclusively, not allowing for b or g connections. In the router menu Wireless > Basic Wireless Settings (Manual Setup), make sure the network mode is configured as "Mixed".
Please add a comment to this solution if one of these items resolved your problem. If you suffered from a different issue I did not think of, it would be nice to drop me a line, too. Other people will benefit from any experience you made.
Go to the Settings Menu, Select the Wireless & VPN option and see if you are in Airplane mode, if you are turn that off. Then select Wi-Fi. See if Wi-Fi is turned on. If it's not turn it on. There should be a list of available Wi-Fi routers. If one is not selected select one that is open or that you have the password to. If none are open or they are locked and you don't have a password, you'll need to get a password for one, or install your own Wi-Fi router.
Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
To reset a Kindle Fire 1st Generation:
1. From the lock screen, slide the Unlock Bar from right to left
2. Use the keypad to enter characters into the password/PIN field four times
3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
To reset all other Kindle Fire models:
2. Use the keypad to enter characters into the password/PIN field five times.
3. When prompted to reset your Kindle Fire, tap "Reset"
To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
1. Slide and release the power switch to turn on the device or exit sleep mode
2. Enter "resetmykindle" in the password field and press the enter key on the key pad
3. Wait several minutes while your Kindle restarts
To reset a Kindle (5-way controller):
1. Press and release the power button to turn on the device or exit sleep mode
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
To reset a Kindle Touch or Kindle Paperwhite:
2. Tap the password field to bring up the onscreen keyboard
3. Enter "111222777" and select "OK"
If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
2. Select the "Manage Your Devices" link
3. Select "Deregister" to deregister your device from your account
Sync your Kindle, then register again.
If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
My daughter forgot hers as well and Kindle support is the only place to get the right support regarding your specific model and directions for resetting your device.
From the Home screen, press the Menu button.
Select Settings, and then select view next to Wi-Fi Settings.
In the list of detected networks, choose a network to connect to it.
If your Wi-Fi network and router support WPS (Wi-Fi Protected Setup), your Kindle will detect it.
If you don't see your network in the list, you need to add the network manually.
If the network is protected by a password or WPS (Wi-Fi Protected Setup), enter the password and then select Submit.If you don't know the Wi-Fi network password, contact the person who set up the Wi-Fi network.After you connect to a Wi-Fi network, your Kindle automatically connects to it again whenever that network is in range. If more than one network is in range, your Kindle automatically connects to the last network used.
Swipe down from the top of the screen to show Quick Settings, and then tap Wireless.
Verify that Airplane Mode is Off.
Next to Wi-Fi, tap On.
Tap a network to connect to it. If you see a lock icon, a network password is required. Enter the Wi-Fi network password, and then tap Connect.Note: If you don't know the password, check with the person who set up the network. This password is not your Amazon account password.
After you connect to a Wi-Fi network, your Kindle Fire automatically connects to the network again when it's in range. If more than one network is in range, your Kindle Fire automatically connects to the last network used.
well maybe did you change your wifi password because that happend to me and then i rembered i changed the password for my wifi i hope this helped if not im sorry .
