Washer will just stop part way through the cycle with no error code. I am looking for a service manual with a schematic so that I can check all of the interlocks.
Michael, I too am looking for the same as you for my Whirlpool 8.5kg WFE1485BD. Similar machine as yours but newer. I need the schematic diagram to see how the door interlock switch works. Your problem sounds like that as well, have you tried manually working the switch with door open and checking with an ohmmeter? Does your machine give a door open warning light? I have pulled my door switch out and disassembled it but can't work out which contacts get switched. Please email me if you find a service schematic and I will do the same: [email protected]
SOURCE: Whirlpool duet washer problem
Our machine was giving the HF code at 37 min after over filling with water. I unplugged the machine, popped the top (took the 3 torx screws off the back) pulled the small hose off the pressure switch sensor (round sensor on the upper back right of the machine) and blew it out just by mouth. It obviously cleared some junk. It works fine now. (also unplugged the 6 wires on the sensor, turned it around and blew on that and heard it clicking, so I knew that was ok.) Hope this helps someone.
SOURCE: whirlpool duet washer sport ht - error codes
FYI: The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground. Just thought this would be helpful as I just did this as of 5 min ago. Should take 10 min. or less.
SOURCE: Whirlpool Duet Washer-error code "sud"
Just take off the bottom kickplate (3 screws on the bottom). You'll see the pump front and center. Twist the front face of the pum slowly to the left. All the trapped water will flow right out towards you. There could be a sock or some other debris there. Unclog, screw that faceplate back in and start it up.
