Power it on and blue sparkles at bottom switches to black and white lines to nothing. No picture at all and ido know if pushing buttons is doing anything with no screen.
Contact the authorized service center for Toshiba, or any experienced service technician. Gopakumar Gopalan Google
SOURCE: Toshiba regza went black, then the northen lights appered!
prosit, If unit can be opened, I recommend you visually inspect the main power supply printed circuit board for "bad" electrolytic filter capacitors that may be faulty and failed prematurely! Lots of DIY videos at YOUTUBE that you should view before doing a "teardown" !!! Remember THIS!!! You MUST document your teardown with video or digital stills so before disconnecting any connectors to the board so you can put unit back together exactly as it was before you started any board repair work!! e.g. replacement of filter capacitors, fuses, resistors, and solder joint inspection of through-hole and or surface mounted active and passive components. DO YOUR WEB RESEARCH OF YOUTUBE VIDEOS FIRST!!!! Good luck guy. Keep us tech's informed of your progress by doing additional posts (comments) here on fixya. 12fixlouie
SOURCE: Plasma TV picture failure
Sounds the Y-Sustain section has damaged. Seek tech support. For more details type in this site name "Electro-help"
either to Google or Yahoo search box [not
in the address bar of your browser], and click search or press
Enter. It is an electronic equipments
service help site. Note the
position of hyphen in between words in site name. The site will appear as it is in
web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site
name, either at the bottom part of first search page, or at the top of second
page. Detailed
descriptions are there to help you. Sometimes,
clicking on advertisements by the side and bottom of each post might help you
to get details about the availability of spare parts; price and more.
