I am needing a code for our symphonic dvd player to go with my Panasonic remote. any help?
Panasonic remote control have no set-up codes to Symphonic DVD player. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too.
http://electro-medical.blogspot.com/
SOURCE: DVD Remote
You can find the remote for DVD-F87 in the link below.
DVD-F87 Original Replacement Remote
SOURCE: I have an A350 in good condition but not a working
I would recommend you just go to your local walmart or kmart and buy a universal remote control for just a couple of dollars. A universal remote should work just fine, and it would be a lot cheaper than a manufacturer's replacement. If it doesn't work, you could try googling "replacement remote for........(type of dvd player)." I hope this helps, and good luck! Sincerely, Der Strom
SOURCE: Codes for a sony blu ray player using a panasonic remote
You can't unblock the Blu-Ray portion, but can unblock the DVD function. Visit the site named 'Electro-help' for more details. Click this link. View it in Timeslide or Flipcard option, which can be selected from the drop down box menu by the Sidebar tag, at the top left corner of the display window. You can also click the Home tab to see the latest updates. It will make search easier. There are more than 1400 posts to different brand TVs till now. Setup proceedings and code list to different brand remote controls also included. Pull up older posts or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
