When I makes a calling out or in it won't let me, not event single ring
SOURCE: nokia 6300 canot send text message
Hello there! thanks for using Fixya.com!
Kindly check the message center number from your mobile phone if its already there or you can contact your Network Service Provider to provide you the specific and correct message center number. Usually, you don't have to touch these numbers. If you suspect they are incorrect, contact your mobile service provider and ask them to send an Over The Air (OTA) message with the correct information in it.
Please be informed that the SMS Message Center Number is a phone number that acts as a gateway for transferring SMS messages between cellular devices.
Some tips!!!
Where are these numbers stored?
Hope this will help!!!
SOURCE: My Nokia E52 does
Check your message settings, there is a option called Message center number.If the number is incorrect you wont able to send messages while you can receive messages.This Message center number is provided by your service provider.Call your customer care for message center number and enter it to your phone and save in message center number box.Then you should send the messages.
SOURCE: the phone wont allow me to text send messages or
you must probably have your outgoing calls barred and the best way to do this is to go to settings and check for call settings and unbarr all outgoing calls, the default code is mostly 0000
SOURCE: cant make a call,cant receive a message event text
Hi,hope Your Sim card is still working?, When a cell phone has issues with not making calls, not receiving calls, you have to contact with your service provider of the network you are using..
When you contact them they will help you out with message problem, and with making calls issues.
You can go to the nearest outlet where their office is located in your area...
I guess that will do..
Thanks for using fixya....
