Compressor will not kick on, fan in freezer and back running though
Sounds like either the compressor is out or the relay that starts the compressor is out. I would try replacing the relay/overload on the compressor and hope for the best. if you have a continuity tester then check from each of the 3 posts sticking out of the side of the compressor that the relay/overload push on to fo one of the copper pipes coming off the compressor..no continuity is good if you get continuity then the compressor is shorted and ruined
