LG DLE2514 Electric Dryer Logo
Gayle White-Norton Posted on Mar 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg dryer wont start lights on on but wont start
Tedowen
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • LG Expert 536 Answers
  • Posted on Jul 05, 2014
Tedowen
LG Expert
Level 2:
Prodigy:
Answers
536
Questions
0
Helped
264744
Points
943
Check the thermal fuse, start switch on the control panel and door switch because all three are more likely the cause of the dryer not starting up.
The door switch is often the culprit in this type of fault, although a faulty drive motor is not ruled out.
Lg wle1501w dryer no power
Since its brand new it should have a warranty I would use that since you trying to could void that.
Jul 05, 2017 • LG Dryers
My LG DLG2526W gas dryer wont start
I had a problem like this and our fix was to reach in and turn the drum a half a turn and push the start button. it worked for us because the motor had a dead spot on motor and once moved pass that spot, it did its job. you may have a different problem but, try it.
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 • LG Dryers
Turned on dryer & tried to start but it gave a load thud noise & wouldn't go. Stop it then re-started a light came on stating clean filter. Clean filter & look inside that area to see if...
there is a sensor located beneath the lint filter, more the likely the dryer sheet residue is on it, gently brush it off, it has two screws. As far as the loud thud noise is/may be a problem with the drum/rollers/glides/belt/idler arm/motor Here is a website that will assist you, once the filter light goes off and the drum will not turn.Good Luck Tim
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Machine wont start. lights come on but nothing happens when I hit start.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
My new lg direct drive washer just quit mid cycle, it wont start back up the code indicated power outage, but it comes on just wont run
heatman101
15helpful
4answers
My lg tromm DLG3788W gas dryer is not heating, it says check filter. other wise it works fine. where is the filter at, i know the one where i open the door and clean the vent everytime i use it. thanks
I just cleaned those sensors at the bottom of the filter, it worked like a charm. The dryer is now drying perfectly, I did not know you were not supposed to use fabric sheets with this dryer. Now I know, Thank you for the good information.
No heat after drying several loads
the vent in your house may be stop up in the wall.
Top LG Dryers Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Dryer Expert? Answer questions, earn points and help others
