The freezer will go for 5 or so days then it will sound the hi temp alarm. I checked the defrost timer thinking that it was defrosting for too long, but wasn't the prob. I let the freezer run for another week and then the high temp alarm came on for a few hours then went back off later in the day (i thought maybe it was related to it being really hot outside). Today it was raining outside and pretty chilly, and the alarm was on all day and did not go off. I removed the cover that covers up the freezer coils, and noticed that it was half snowy and half thawed (the coils i mean). Seems to me like this indicates something--but i'm just not sure what. I took pics if anyone would like to see them. Thanks
I would start by checking the compressor relay.
Remove the relay from the compressor and shake it. If small particles
come out or it sounds like a salt shaker or there is no sound at all or
it smells and looks burned then it is bad. Replace it.
if that doesnt work and shud u wish to get back to us after the above solution hasnt worked.... we wud require the pics u have and the brand and model number of ur freezer
good luck
like i said we wud requie ur model number and the pics u were talking abt ......... just in case so that we can help u better
A 9v. battery in the grill down below. You won't have to remove the
grill but pull a small rectangular panel to expose the battery. High
end Kenmore freezers have a battery to back up the alarm. The six you
see is actually supposed to be a "b" for battery most likely. L.E.D.'s
are tough to tell the difference. Buy an new battery and all will be
well. I hope this helps
Yes, please use the "continue with this expert" option and post the pics.
Thanks!!
Alright, so i replaced the compressor relay, "due to it rattling like a salt shaker", and it it still doing the same thing--except now I cannot get it to freeze water in ice trays.
how do i get those pics to ya
the m/n is 253.9239715
i have a feeling you posted this for someone else.
ok so now i got a little bit more info. I replaced the compressor relay and it didn't fix the problem--COMPLETELY. However, I think I had multiple problems. Now, the hi temp alarm comes on at 1pm every day then goes off after about an hour. So i thought maybe that corresponds with the defrost timer/defrost cycle. I move the timer ahead a little while and waited for it to do it again. IT DID. So my guess now is that the timer is holding it in defrost for too long? would that make sense?
