SOURCE: How do I know when my Samsung Galaxy Tablet is
The Tab takes quite a long time to charge (not sure why). Note that the Tab cannot charge from a computer USB port (only from the included AC adapter. When the Tab has finished charging, it should put out a notification (open the notification drawer by pulling down on the status bar) saying the battery is fully charged and to unplug the charger. Other than that, you would have to install a third-party app like Smart Battery Monitor (see here) and watch that to see when it is full.
Hope this helps,
Alistair
SOURCE: samsung galaxy tablet is not
Make sure you are using the AC adapter as the Tab cannot charge solely from a USB cable connected to a computer or similar. If it is still not charging, your device's battery or connector has probably failed and will need to be replaced.
Hope this helps,
Alistair
SOURCE: SAMSUNG GALAXY TABLET NOT CHARGING OR TURNING ON
Hi buckpot2001,
To correct this issue, please follow the steps below.
1. Press and hold down the power button whilst at the same time touching the screen (you may have to wait up to 30 seconds as it clears the system).
2. You will then notice the battery indicator pops up.
3. The Tablet will then reboot. Everything goes back to normal.
4. If that fails to work, connect the power cable and repeat the above steps.
Hope it helps.
Thank you for using FixYa.
SOURCE: my galaxy tablet GT-P7510 wont turn on its fully charged
Hold down power up button until it starts. It can take up to 30 seconds before it restarts.
SOURCE: Samsung galaxy tablet is frozen
Couldn't even turn mine off ... read up on this.
SIMPLE SOLUTION: Hold the power button down for more than ten (10) seconds. WORKED!!!!
