Question about GE Remote Original Jc024 Remote Control Unit Rc24914e Universal
Need all codes for GE j024
Need to program my GE j024 remote for my toshiba 19lv61k
    Top Expert:
  • GE Master
  • 76,173 Answers
0287,0288,0283. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Posted on Mar 11, 2014
4 Suggested Answers
6ya staff
SOURCE:
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: Ge remote control #24921
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
Anonymous
  • 33 Answers
SOURCE: Need Hitachi TV code(s) for GE Universal Remote #24912 - thanks!
here is the 2 links for the codes, they are pdf files. hope this helps
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-New.pdf
Posted on May 05, 2009
Anonymous
SOURCE: Direct Entry Code for GE television for GE RM24911 Universal Remote
NECESITO HOJA ADJUNTA DE CODIGOS DEL RM24911 POR FAVOR
Posted on Apr 14, 2010
Universal remote code for Toshiba Model 19LV61K
Codes are in the remote; therefore, it would be necessary to identify the universal remote you are intending to use.
Jan 02, 2017 | Televison & Video
Does anyone know the numeric code to unlock the DVD tray inside this Toshiba 19LV61K TV/DVD? There is a disc stuck inside the DVD tray, and the film will play without a problem.
There is no such code to get out the strucked disc. you have to take out it by manual method. If you wish to get some details; check the site linked here. Pull up older posts.
If you insist on a numerical code, and have determined, won't do anything without it, try this alpha numerical code {VWXTB 028103820489} Followed by Menu button.
Good luck.
Mar 24, 2016 | Toshiba Televison & Video
Tammy its troy agian can't get urc 8820 Cisco channel up and down buttons to work on my Toshiba 19LV61K
Set it up with an other code said for Toshiba. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Sep 21, 2015 | Toshiba Televison & Video
I have a GE 24944 Universal Remote that I need to program to a Toshiba HD DVD (A3) Player. No code works from the manual. Can anyone please help?!
If you have a GE universal remote, you can use its "code search" function to find out whether any code in its library can control your Toshiba player. If nothing works, you may have to try another programmable remote as all programmable remote do not contain all codes.
Oct 28, 2014 | Televison & Video
How do I program a GE universal remote RC 94904-B 1129 to a Toshiba TV?
Your GE universal remote should have a "code search" capability you can use to find a suitable code. Codes are stored in the remote. If a thorough search produces no result, you may have to try another universal remote. Not all remotes contain the same codes.
Sep 19, 2014 | Televison & Video
Ge 24922v4 universal remote control code list for toshiba?
GE 24922 Instruction Manual Page 6 Programming Your Remote
This link should provide the info you need. If the link does not work, Do a search on the web for " GE 24922 remote set-up"
May 25, 2014 | GE 24922 6 Device Universal Remote...
Toshiba 32a14
  • The GE remote control is not identified as universal
  • The GE remote control may not contain a code applicable to your Toshiba TV.
All universal remote controls do not contain all possible codes.
Jan 16, 2018 | Televison & Video
Need codes for ge universal remote for toshiba CF19G22
go to www. fitness.manualsonline.com or www. remotecodelist.com
God bless you
Jul 06, 2012 | Toshiba CF19G22 19" TV
I have a ge universal remote and have a toshiba tv dont know codes and how to programe it could you please help?
Which GE universal remote do you have? Does the remote use a 3-digit or a 4-digit code? To program most GE remotes for a TV, turn on the TV. Then press and hold the Code Search or Setup button until the indicator light comes on. Then press and release the TV button. Enter the first code available for your device. The indicator light should go off then check if the remote controls the functions of the TV. Repeat the above steps if the code doesn't work or doesn't control all the features of your TV.
The manuals and code lists for GE remotes are here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
Toshiba 4-digit TV codes are: 0159 0178 0109 0120 0181
.............0105 0049 0095 0170 0260 0358
.............0394 0924 0012 0095 0117 0141
The 3-digit codes are 170, 181 or 641 for Toshiba HDTVs.
Please note that the remote probably only has codes for devices that were released 6 months or more before the remote was programmed. If your TV is newer than your GE universal remote, you may need a newer remote.
I hope this helps.
Jul 06, 2011 | RCA Televison & Video
GE Remote Original Jc024 Remote Control Unit Rc24914e Universal Logo
519 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
