SOURCE: car dies when stopping or slowing down, hesitates on acceleration
check for a vacuum leak,you could possibly hear a whistle under the hood,or you can spray starter fluid near the intake manifold where the suspect leak could be and if the engine accelerates it has an vacuum leak,try the simple things first,can also be a clogged PCV valve,it is in the valve cover somewhere and it will have a rather large rubber hose going to the intake manifold
SOURCE: toyota wont start
EFI= to Electronic Fuel Injection. If you have sparks, check for fuel delivery. Another is the electronic module on your distributor, but you already said you have spark and hopefuly the right "timming" too. So you checked the current and is OK, what else do we have.The computer? Remeber that Camry,is the cadillac of the Toyota. Some even have Lexus parts. So expect parts to be rather expensive!.
SOURCE: Truck starts then when engine gets warm it dies
Try removing the petrol cap on the tank, if the truck runs ok then you have a blockage in a hose somewhere.(vacuum created in fuel tank)
SOURCE: Erratic Idle - When starts the idle is about 1100 RPM as it warms up, it goes to 700 - 400 RPM
Have you "reset" the computer on the car. When parts are replaced, the comp continues to run the vehicle on all the old settings which can drive you nuts because nothing you do will fix a problem. Usually, taking both battery cables off and waiting for 15 minutes will reset the computer. If this does not do it, then ask a dealer how to reset yours.
