Step 1 : Identify the DVR. • Launch the Alien-DVR-Reset-Tool.exe from the USB stick. The USB stick must be present initially but may be removed once. ...
Step 2 : Obtain a Reset Code. Ring System Q on 01246 200 000 and quote the. • DVR's serial number. ...
Power off the DVR: Make sure the DVR is powered off by disconnecting it from the power source.
Locate the reset button: On the back or bottom of the DVR, you should find a small reset button. It is often recessed and may require a pointed object like a paperclip or pin to press.
Press and hold the reset button: Using a suitable tool, press and hold the reset button for about 15 to 30 seconds. This will reset the DVR to its default settings, including the password.
Power on the DVR: After releasing the reset button, reconnect the DVR to the power source and power it on. The DVR will go through a startup process.
Access the DVR: Once the DVR has finished booting up, you should be able to access it using the default login credentials.
Username: The default username is usually "admin" or "admin1234". If these do not work, consult the DVR's user manual or documentation for the correct default username.
Password: The default password is typically either blank (no password) or set to "4321". If none of these options work, refer to the DVR's documentation or contact Samsung's technical support for assistance.
You cannot connect the two directly. The IP address can be found in the setup page of the DVR, You then type that address into your browser to get into the DVR. The DVR must be connected to the internet using a port on the router.
