I recently plugged in my blackberry via USB to my computer and received a request to enter my password. If the password was incorrect 10 times then my blackberry would automatically wipe the data.
I had placed a security code to access my blackberry such as: 4404 When I tried typing this code on the BB desktop manager..on my computer. The code was not accepted. i tried over an over, until i realized the blackberrys number key also has a letter key.
Thus instead of typing the numbers 4404 on my computer, i typed the equivalent letter on the 4 key. if 4 is G then i typed gg0g
If this is verizon carrier then you should dial *86 and enter your four digit pin code. Then listen for the option that says change personal options (should be number four) then you can change your phone message or use a standard one if you wish.
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None. Text-Entry Methods: iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it. TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key. TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key. Text-Entry Modes: Primary - You can set your Primary entry mode to any iTAP or TAP entry method. Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode. Numeric - Enter numbers by pressing the number keys. Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select. To set the text-entry mode or method:
From a text-entry screen, press Options.
Scroll to and select Entry Setup or Text Setup.
Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
To make and receive calls the procedure is same in Blackberry,
You can send and receive messages and click on ALT key to change the letter case from numbers to Letters,
You can use the functions using the Blackberry Menu key and the Track ball,
However the procedure to use options in the Blackberry device differs from Option to Option.
Please write it to us the exact function which you want to use so that we can help you with the same in detail, as there multiple functions in Blackberry.
It's a clear and fully detailed guide on how to unlock a BlackBerry pearl 81XX :
1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (if your BlackBerry have touchscreen) 7. Type MEPD ( you will not be able to see what you are typing ) 8. Type MEP2 or MEP4 ( you will not be able to see what you are typing ) 9. Now the phone will prompt you to enter the mep code 10. if you not already have the code, then i suggestBlackBerryMEP.COMto get it from . 11. Enter the mep code ( you should see "code accepted" ) 12. Restart your BlackBerry .
