My 1967 VW Beetle loses power real bad going up hill why
Almost all 1967 VW beetles came with a 4 speed manual transmission. A few had a "semi-automatic" transmission which was basically a VW manual transmission with an electrically actuated clutch and a torque converter. For the semi-auto, there was no clutch pedal. Instead there was an electrical connector at the bottom of the stick shift. When the driver touched the shift and started to move it to shift gears, the contact would be made and the clutch engaged. This would confuse people if they were used to driving with their hand on the stick shift.
1. If the engine is racing when you go up the hill, then the clutch may be slipping. If you have the semi-auto, then the torque converter may be bad.
2. If the engine is not racing and you're just losing power, then there may not be enough gas getting to the engine. Check the fuel pump output as another answer suggests. The carb's float and needle valve may not be opening all the way, thereby not allowing enough fuel into the carb. Or, you may have a partially blocked main jet in the carb which is not letting enough fuel to flow into the engine.
