Question about Tomtom GO 300 GPS Receiver
My Tomtom 630 cannot be accessed because the touch screen does not work
I have reset the device on 3 occations but the problem still prevails
    Sergeant:
    Champion:
  • Tomtom Expert
  • 373 Answers
Posted on Mar 11, 2014
3 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: tomtom one touch screen not working properly
To get it working again, I used the option to change settings and turn the screen 180 degrees. After that at least you can use the buttons again. I have no answer yet for the adjustment trick, but a new touchscreen is not the answer. It may have something to do with buying charts ready on disk, most people do not know if the map they order is the proper one for the model. This can be checked with tomtom home. Once you have turned the screen 180 degrees, you have a better look on where to push to make it work.
Oce I have a better solution, be sure I'll post it.
Posted on May 24, 2010
d cart
  • 3 Answers
Here is the cal.txt I used for my 720
929 86 480 75
It is really close to perfect
open a text file put these numbers in save as cal.txt copy this file connect tt to computer go to explorer/aka file manager find tomtom drive and paste it in.
That is it. test it out.
Posted on Jul 20, 2012
How to change screen
You cant access the tomtom dive directly when its connected to a computer
Sep 03, 2014 | Tomtom Go 630 GPS Receiver
How do you recalibrate the screen of a tomtom go 750
Pls factory reset the device and calibrate the touch with its first boot.
Regards:Himanshu
Aug 28, 2012 | Tomtom GO 750 LIVE GPS Receiver
Windows 7 will not recognize my tom tom go 630
Lots of folks having this problem with differernt model TomToms. It's the USB on the TomTom.
You'll need to "reset" the unit, using a paperclip or narrow pen, hold the reset button in for about 5 seconds and you should be good to go. On the 630 it's on the bottm, right next to the USB port.
Hope this helps!
Brian
Apr 21, 2010 | Tomtom Go 630 GPS Receiver
My TomTom GO 630 is frozen on locating a GPS signal. How do I reset
Mine does this about once every couple of weeks. It just requires a "soft reset." To do this you just take a pin or paper clip and press the reset button located on the bottom of the TomTom Go 630 to the left of where you plug in your charger/usb connector. This is a "soft reset." None of your settings are changed... it's just like rebooting your computer. It just clears your temporary memory (like RAM) so all it would possibly lose is your current route if you had just set one. You probably can't since yours is frozen but DO NOT go through your device menu screens and "reset to default" because you will lose all of your settings and saved locations that way.
I want to change the language on my tomtom go 630 from afrikaans to english
To expand SQUIRESXXX's solution a bit:
From the map screen, touch anywhere to get to the main menu.
From the main menu, tap Change Preferences.
Scroll through the screens until you reach Change Language (shown by a set of flags). Tap that icon, then select the language you want.
Dec 20, 2009 | Tomtom Go 630 GPS Receiver
How do I reset my tomtom go 630 to give instructions in English?
From the main screen:
Tap Change Preferences (the blue wrench/spanner).
Scroll through the preference screens (orange arrow in the bottom right-hand corner) until you come to the icon with several flags. This is Change Language,
You will come to a list of languages. Scroll up or down until you come to the language you want. Tap it. Answer "Yes," then choose the voice you want to hear.
That's it.
Dec 08, 2009 | Tomtom Go 630 GPS Receiver
When I switch on my device I get a flashing white "X" in a red circle. The small picture of the hard drive[?] also appears on the bottom right of the screen. I have tried re-setting several times to no...
First turn your firewall off (if you have one).
You need to go into your 630 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 630 ,
Bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 630 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button,
when done, go back and to device (option in top of your screen) and select disconnect device, restart your 630 and it should be back to life with the upgraded software.
Hope this Should solve your problem else Call their tech support at no charge (866-486-6866, Glen) , really good service
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 13, 2009 | Tomtom Go 630 GPS Receiver
TomTom Go 630 malfunction
re install/repair the software
May 04, 2009 | Tomtom Go 630 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
Top Tomtom GPS Experts
LP
Marvin
Marvin
Ekse
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
