Since there is no reply from other expert let me give you some hints.If you can receive calls with this condition, there are two possibilities to cause this, Display(LCD) and the Main Strip (pata).So, first put another LCD and if the problem persist change the Strip.Even if there is no effect the last thing is to check the PCB (board) and the main strip connector.I think this may help you what to do.Thanks for visiting fixya
Its an LCD problem. if you have the means to take the phone apart, carefully remove the LCD assembly and clean its contacts and the circuit board pads. If its still the same, only a replacement can solve it.
If A vertical strip appears on the screen when recording a dark background or the subject is blooming or silhouetting, you need to adjust the BLC.
* The contrast between the subject and the background is too great for the camcorder to operate normally.
* Make the background brighter to reduce the contrast or use the BLC function while you are recording in a brighter environment.
BLC (Back light Compensation)
* BLC works in CAMERA/M.REC mode.B
* Back lighting exists when the subject is darker than the background:
1. The subject is in front of a window.
2. The person to be recorded is wearing white or shiny clothes and is placed against a bright background; the person?s face is too dark to distinguish his/her features.
3. The subject is outdoors and the background is overcast.
4. The light sources are too bright.
5. The subject is against a snowy background.
1. Set the power switch to CAMERA mode.
2. Press the BLC button.
Normal - BLC - Normal
BLC enhances the subject.
Notes:
* When NITE PIX to set to ON, the BLC function does not work.
* The BLC function will not operate in EASY mode.
