Behringer Xenyx 802 8-input 2-bus Mixer W/ British Eq ! Logo
T
Tom Hall Posted on Mar 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Latency during recording - makes playing in time impossible
I am recording or overdubbing guitar and vocal parts to rhythm tracks and hearing what I play with a delayed signal. The delay is a fraction of a second (hard to tell how much), and it makes playing in time impossible. Frankly, it's infuriating. I never had this issue back in the days of 4-track recording. If you can help me solve this issue I would be incredible grateful to you.
Michial Gueffroy
Level 3:
President:
  • Master 1,140 Answers
  • Posted on Feb 16, 2015
Michial Gueffroy
Master
Level 3:
President:
Answers
1140
Questions
0
Helped
532660
Points
2214
Here's something that will help:http://www.asio4all.com/ Follow all the information.
Joe Patch
Level 2:
Sergeant:
  • Expert 336 Answers
  • Posted on Mar 16, 2014
Joe Patch
Expert
Level 2:
Sergeant:
Answers
336
Questions
0
Helped
109762
Points
574
I can relate well to this. I think the problem would mostly be between the software and sound card instead of the mixer, I'll tell you why. I have found over the years that each type of sound card will have different latency time, even if they are the same. Any time I have ever replaced a sound card, I always had to resync all of my tracks. Anytime I've changed to a different operating system, I went through the same thing. Most times I have changed connections through different mixers, inputs, interfaces, and connections TO the system has no or very little effect.
Jim Cox
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Mar 12, 2014
Jim Cox
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
Helped
4723
Points
56
I can totally relate, Tom. Good old multitrack recorders!
This may sound stupid, but you don't have like a slap back delay turned on by mistake, do you? Other than that, I'm afraid I'm not much help.
2 Related Answers
Anonymous
  • 87 Answers
  • Posted on Dec 08, 2010
SOURCE: I can't seem to figure out how to record one track
This is a common problem with digital recording. Simply put, it takes some time to convert analog (audio) to digital and then more time to convert it back. So, your playback track goes through conversion and introduces some delay. You don't hear this because you have no zero reference. Your recorded sound goes through the A/D converter and also incurs some delay. When you play them back together, you hear the difference in time from one track to another. Most pro recording programs have some method to minimize or cancel the delay like slipping the tracks so they all start together. Pro Tools just introduced a version that automatically does this. They have always had what it called "low latency" monitoring which attempts to keep the "shortest" digital/analog path so overdubs are close enough that we don't hear any issues. So, since you talk about the mixer but not the recording program, I can't tell you specifics but I'd look into the recording program for time alignment settings and options. If you have a manual for the recording program, try to look up latency.
muntejaya
Muntejaya Ginting
  • 10422 Answers
  • Posted on Feb 10, 2011
SOURCE: Bad latency ,ive tried all drivers available for
Hello, you can downloaded it at: www.nodevice.com/driver/category/MP3_Player.html
Regards
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
tip
Studio Recording at Home; Part 1
For all of the musicians who want to record their demo, or even your next album, without paying pricey studio fees, this is the tip for you!<br /><br />First, let me say that it doesn't matter what DAW software you're using, as long as you're familiar with it and can navigate it easily.<br /><br />For that "full" sound that you hear on most recordings on CD and radio, here's a what you've gotta do:<br /><br />4 guitar tracks (two for each side of the stereo image, pan two out just a bit farther than the others).<br /><br />2 bass tracks (one recorded direct in [DI], the other amped)<br /><br />A single drum track<br /><br />Vocals to taste<br /><br />For the guitars, if you don't have an amp, or the equipment to record an amped guitar, there are plenty of amp simulation programs available. If you are using an amp, you'll want to place the mic in front of the amp, slightly to the side, pointed at the midway point between the center and the edge of the speaker.<br /><br />For bass, recording DI without a DI box can be a pain. That's where the amp sims come into play. Record two tracks simultaneously, and only apply the amp sim to one track.<br /><br /><br />That's all for this tip. Stay tuned for part Deux of Studio Recording at Home!<br />
on Feb 12, 2011 • Music
I can't seem to figure out how to record one track over another without a delay problem? I am using the behringer 1202 mixer into my computer. No problem recording but can't do multiple tracks. I'm new...
Auto punch -does this allow the recording to begin at a particular time without manual intervention, i.e. the pressing of a button? Thanks.
Yep, that's what its supposed to do. You set the start (and stop) points and it punches from play to record so you can pick up just before where you goofed up. I'd suggest you put the punch-in point at a natural transition to what you're recording - like a pause in guitar part of between verse/chorus of vocals. If you try to punch into the middle of a guitar run (for example) the results may be less that satisfactory. Make sure you sing/play along with the playback so the transition sounds natural - don't try to just pick up after the punch.
I want to buy a Tescam 2488neo. But i got a question before I buy it. Question- Can I record songs or musics multi-times? I mean, record acoustic Guitar first, and then record ...
Here is a link for you to look at:http://www.tascam.com/products/2488mkii.html Look under resources to download the manual or a Beginners Guide to Recording.
I was just wondering if its best to record seperate tracks at different times of if its ok to mic my guitar and mic the vocals using two inputs but recording at the same time?
Whichever works best for you is best. You can always lay down a scratch track for each like this and then lay down another track to replace whatever you didn't like using the scratch track as a guide. Erase the scratch tracks that you don't need before you mix down. I hope this helps.
Boss 900 digital recorder
from reading instructions when you record channel 1 and 2 you are recordind channel 1 in stereo so you only recorded channel 1 try rcording on chanel 3 for vocal hope this helps
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
