Yes, I am having the same problem. Then when it finally stops/cycle ends I get the F6 error message. The manual says F6 is a "temperature stop fault." What does that mean? And how to fix or troubleshoot it? How did you end up fixing yours?Yes, I am having the same problem. Then when it finally stops/cycle ends I get the F6 error message. The manual says F6 is a "temperature stop fault." What does that mean? And how to fix or troubleshoot it? How did you end up fixing yours?
You can't post conmments that contain an email address.
The meaning of error code F6 can vary depending on the brand and model of the washing machine. Here are some possible explanations for F6 error codes on different brands:
Whirlpool: F6 error code on Whirlpool washing machines typically indicates a problem with the motor drive tachometer, which measures the motor's speed. This can be caused by faulty wiring or a failed motor control board.
Kenmore: On Kenmore washing machines, F6 error code can indicate a problem with the motor or motor control board. This can cause the washing machine to not spin or agitate properly.
Maytag: F6 error code on Maytag washing machines can be caused by a problem with the communication between the central control unit and the motor control board. This can cause the washing machine to not start or complete a cycle.
LG: On LG washing machines, F6 error code can indicate a problem with the motor or motor control board, or a communication error between the main control board and the motor control board.
It's important to consult the user manual or contact the manufacturer for more specific information and troubleshooting steps based on your specific model and error code.
KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Asko F6 error is apparently a motor fault. The motor could be jammed, open circuit , burnt out?? It may just be a broken wire or connection come off. Check "Google" and type in Asko F6 error. There is a lot of info about it.
F06
Drive motor tachometer error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Hi!!
The F6 error means Drive motor tachometer error
Potential Causes
• Check the MCU
Replace failed component.
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
