DBPOWER for Apple iPad 2, iPad 3, and iPad 4 Logo
J
Janice Hamilton Posted on Mar 12, 2014
Frozen page in an E book novel. Can't go forward or backward. Everything else works. I can return to home screen but not to library. Touch does not respond on the page which froze. Thanks
Pat Ring
Level 1:
  • Contributor 39 Answers
  • Posted on Mar 12, 2014
Pat Ring
Contributor
Level 1:
Answers
39
Questions
0
Helped
21705
Points
71
There usually is a reset pinhole where a straightened paper clip can be inserted to press an internal switch. this hole is usually on the edge. press and hold the switch for up to 10 seconds lightly. then the ereader should restart
My kindle screen is frozen and i cant switch it off either, can you help?
hold the power button for like a minute it should reboot
1helpful
Kindle paper white won't move from the first page that shows up.
Try swiping your finger across the middle of the screen from right to left. This action turns the page forward. Swiping your finger across the middle of the page from left to right turns the pages backwards. I don't think the icon on the bottom is for page turning.
Tablet frozen can not turn it off, screen will not changeto home page
try to hard reset it. power off first then hold vol down, menu button and power button.then follow the steps it will show
2helpful
Tablet frozen will not return to home screen
Try to hold the power button down until the tablet reboots.
Frozen reset
If the iPad has frozen on a screen press and hold both the lock and home buttons for about 30 seconds. This will hard reset the iPad and it should then boot normally.
Forgot password
Go to Barnes & Noble's website on your computer and select the option to create an account. Enter your full name, email address, debit or credit card information and select a user name and password when prompted.
If you have a Barnes & Noble account, skip this step.
Power on the Pandigital Novel and tap "Settings" on the home screen.
Tap "General, and select the "B&N Account" and "Password" fields and enter your Barnes & Noble account login information.
Reading ebooks is not the only activity you can enjoy with the Pandigital Novel.
The multi-functional device will also allow you to listen to music, watch videos and browse through your favorite images.
The Pandigital has a speaker located in the back of the device and an earphone jack to accommodate your listening needs.
To get started, you will need to either download media from a computer or purchase ebooks from Barnes & Noble online.
Downloading Media
Connect the Pandigital Novel's USB cable into the compatible mini USB port on the right side of the device. Plug the other end of the USB cable into the computer's USB port.
Click on the computer's desktop "Start" menu.
Choose the "My Computer" or "Computer" folder in the desktop Start menu.
Double-click to open the "PD_Novel" drive in the My Computer/Computer folder.
Inside the drive there are four separate folders "eBooks," "Photos," "Music" and "Videos."
Drag compatible media files stored on the computer to the compatible folder inside the "PD_Novel" drive with your mouse.
For example, drag audio files to the "Music" folder.
The Pandigital is compatible with text formatted as ePub and PDF, audio files formatted as MP3, AAC, WAV and OGG, video files formatted as MPEG-4 and images formatted as JPEG, BMP, PNG and GIF.
Disconnect the Pandigital Novel from the USB cable.
Playing Media
Press and hold the "Power" button, located on the left side of the device until the boot up message appears on the screen.
Select a media option in the "Application Quick Launch Bar" at the bottom of the screen: Reader, Music, Videos or Photos.
Tap the desired song, video or image and tap "Play" or "View."
Tap the "Pause/Play" and "Previous/Next" options to control the file or go to the next listed file.
Setting Up Wi-Fi
Turn the "Wi-Fi" button, located on the top of the device, to the "On" position.
The Pandigital Novel will automatically scan for local Wi-Fi Networks.
Tap the desired network from the list of found networks.
Enter the network password, if prompted. Then tap "Connect." When connected, tap "Next" to continue.
Purchashing eBooks
Tap to go back to the home screen.
Select "Bookstore" from the home screen.
The Barnes & Noble bookstore will open in the Pandigital Novel screen.
Search the website for ebooks to purchase.
Tap on the book cover and select either "Buy Now" or "Get Free Sample."
Tap "Yes" to download the media cover to "My Library" when prompted.
Go back to "My Library" on the home screen and tap on the media cover.
Confirm to download the ebook to your Pandigital when prompted.
The entire media file will download.
http://www.pandigital.net/userfiles/file/Downloads/UG_PRD07T-1_v3.4_09-10-10.pdf
Barnes & Nobel
http://www.bn.com/
1helpful
2answers
Overdrive media console is frozen on my iPad 2
Double tap your home button (middle bottom). When you see your open apps press and hold on the overdrive app until it wiggles. Tap the red X to close it. Then, tap on the overdrive app icon again to reopen the app. You'll be at your bookshelf but, tapping on the book you were reading will return you to that page.
Top DBPOWER Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a DBPOWER Tablet and eReader Expert? Answer questions, earn points and help others
