kawasaki PVS1080 Logo
Posted on Jun 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery charger I lost the part that connects between the battery pack and the charger , does anyone know where to get a replacement.
Anonymous
Level 3:
  • Master 355 Answers
  • Posted on Jun 13, 2009
Anonymous
Master
Level 3:
Answers
355
Questions
11
Helped
145320
Points
1134
You can buy it to any electronic or computer shop nera you like Bestbuy , Radioshack or any other store just give them model of your device and they will be able to provide you that....
or
click on hyperlink:
buy replacement ac power power cord charger adapter KAWASAKI PVS-1080
2helpful
2answers
My bosch al 1860 cv charger is not charging the batteries although they are flat batteries if i put it in the charger the green light stays on
Hi, lithium batteries are funny old beasts. If your battery is completely flat, your charger will not recognise that a battery is inserted and will not attempt a charge cycle. If you have a dud cell, the battery voltage will rise immediately and the charger will think that the battery is fully charged. You will need first to check if you have any voltage whatsoever at the battery connections. If zero voltage, it might be recoverable using a variable voltage power supply and directly charging the battery. This can be dangerous if you do not know what you are doing and the battery may explode or catch fire if charged incorrectly. If you do have say 15 volts on an 18 volt cell, then you need to monitor the battery voltage to see if it rises instantly when connected to the charger. If it does, battery is faulty, if not then the charger is faulty.
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
1helpful
I have a PV-IQ404 Panasonic Palmcorder that the power pack has been lost from. Can this be replaced?
By power pack do you mean the actual battery or the charger unit that plugs into the wall to charge or power your Palmcorder? Either way, bot are available on Ebay as universal units and you should make sure the charger or battery pack is for or a 6 volt capacity. Many chargers for these Palmcorders are labeled as VHS-C / 8MM, that should work with your camera. Universal battery packs are made reversable, meaning that you can flip the battery to accomodate several other camcorder models. I've replaced my batteries and charger for my Panasonic Palmcorder from Ebay.
I have a UniRoss X-Press 300 charger which takes 4 Nicad AA Batteries. I want to be able to charge sealed Battery Pack of 4.8 V. How can I do it with this charger?
You can't as the charger has bad cell detection so the charger most likely has individual circuits for each cell so wont work as a charger for 4 cells in series (such as your 4.8V pack for instance). You need to obtain a charger suitable for 4.8V NiCd battery packs. Assuming your battery pack is for a specific device there would be a dedicated charger available for it Alterntively there are a number of multi-voltage chargers available that will do the job. I don't know what country you are in or what capacity (mAh) the battery pack is so I'm going to assume it's less than 1000mAh or not much more. A globally available charger that will most likely suit is the Ansmann ACS110 I've linked a supplier in Australia but they are also available in most other countries. The only issue you have if you get one is how to connect to your battery pack. Assuming the included plugs may not be suitable then alligator leads & other output connectors that maybe suitable are generally available from places like Jaycar, Radio Shack etc.
3helpful
I lost the battery charger for the BigFoot toy. Can I buy one?
I know you can get these on Ebay. Also most NI-MH 9 volt battery charges will charge this battery pack. You can use a 9 Volt Snap Battery Connector with Alligator Clips to bridge the connection between the battery pack and the NI-MH 9 volt batter charger. This is how I charge this battery pack now. You can probably get the 9 Volt Snap Battery Connector with Alligator Clips at a radio shack or on Amazon... as well as a NI-MH 9 volt battery charger.. don't hook up the leads backwards :)
2answers
Hi, I have repaired 3 Makita 18V 3Ah Li-Ion batteries recently by removing good cells from other faulty batteries. The Voltages are good now on all 3 and they charge/discharge OK on my own charger but...
You can get a 18V replacement Makita battery for your drill. The replacement one is cheaper. Replacement MAKITA BL1830 battery pack 100% compatible with the original BL1830 battery, high quality, wholesale price.
http://www.drillbattery.com.au/buybattery.php/makita_BL1830_power+tool+battery.html
I have a compaq presario cq61 and have been having problems with the charger for quite a while but money is an issue so cannot get a new one just yet, the laptop has 2 lights to aknowledge that the...
YOUR PACK IS NO GOOD
IT MUST RUN WITH NO BATTERY
PACK CONNECTED
SINCE IT DONT THEN THE CHARGE IS WEAK TOO.
YOU KNOW PACKS CAN BE
GOOD
BAD
OR WEAK, OR EVEN ON FIRE, (loL)
4helpful
4answers
How to charge Panasonic lumix DMC-FS4
hello there use your USB cable for charging your camera battery. No need to take out the battery from camera. Some Tips.
  • You may choose our Smart Charger (0.5A,UL listed) for 3.7 V Li-Ion battery Pack to recharge this battery pack. Must charge the battery pack with correct polarity. The estimated charging time is 2.76 hours .
  • You may connect two 3.6v 920 mah pack in either series or parallel connection for making a higher voltage and higher capacity pack.
  • Hope you have those staff with your camera. use that for charging. Follow the link.
    http://www.batteryspace.com/smartcharger05afor37vli-ionpolymerrechargeablebatterypack--ceullisted.aspx
    Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
    Top kawasaki Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Sean Wright
    Sean Wright
    Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
