Question about Sansui HDLCD3250 32 in. LCD TV
Will not hold channel memory after tv turned off and then turned back on - have to go through channel memory step each time
Will not hold channels in memory whether it is air or cable
    Top Expert:
  • Sansui Master
  • 76,177 Answers
Sounds like a main system control memory IC fault. Contact any service technician, or the authorized service center for Sansui.
Gopakumar Gopalan Google
Posted on Mar 13, 2014
6ya staff
SOURCE:
How do I run a channel auto scan?
There are many different ways, because each TV manufacturer calls each menu option something different. In your TV menu there should be an option that says Set Up, or Channels, or something similar. Your TV should be, Menu, pan right to Channel, select whether you are using Air (air meaning antenna, picking up channels that are broadcast free over the air) or Cable (only if you use cable with no box). Then the option below should be auto scan. Allow to run completely. Sanyo DP42D24 User Manual Channel
Apr 06, 2015 | Sanyo DP55D44 55" 1080p 60Hz LED HDTV
Polaroid tv keeps rolling from ch. to ch.
Check whether the micro-switch [Channel up/dn] have struck or not. This might cause the TV to jump from channel to channel. Refer its user manual and make an auto search for on air programs. If the do not memorize any of the channels, the fault is with its main system memory IC.
Aug 01, 2012 | Polaroid 1720-7 Remote Control
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Type of cable from wall cable outlet to tv plus what imput to use Thanks
coax cable and the input on most sets is "TV" use the input button to cycle through the choices. You may need to programm TV to see cable. Go into TV menu look for channel setup. there will be reference to whether you are using air(antenna) or cable. also you must "autoprogram" so TV will lock onto channels that are available.look for that option as well in setup. good luck
Sep 13, 2010 | Televison & Video
NO SIGNAL . CANNOT FIND ANY CHANNELS WHEN I
You need to use the setup menu to specify the tuning band (specify whether you have cable or an over the air antenna) before doing an auto channel scan.
Dec 01, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Tv tuning instructions how to?
The quick user guide is available here: F32648 F36648
Tuning is automatic on this TV, ensure that auto channel search is on from menu.
Advanced Auto
Channel Search
Auto Cable/Air Switch sets tuner
to cable or “off-air” frequencies
during initial setup. Then system
automatically scans for and locks
active channels into channel
memory.
May 06, 2009 | RCA F32648 32" TV
I only get about 5 channels
Make sure in the on screen menu that the tuner is set for CABLE or AIR depending on whether you have cable or an antenna. The channel frequencies are the same for ch 2 thru ch 13 but everthing above that is different depending on your source.
Hope Ya Fix It!
Feb 08, 2008 | RCA TruFlat 27F520T 27" TV
Partial Cable
Hi, Possibly you have to run steup again in the Samsumng TV using your remote, Look for Channel setup, memory, add or search. It would also help you if you would confirm whether it is on cable, air or std. Hope this give you some idea(s). Pls post/comment back should you need further information. Good luck and kind regards.
Aug 12, 2007 | Samsung TXE2745 TV
Won't tune in all channels
Do you mean the channels from the internal tuner which would be channels 22 to 68, or do you mean satelite channels, as I do not know whether this set has a built in satelite receiver? Satelite broadcasters are often changing frequencies or satelites.- Programs come and go!
Oct 20, 2006 | RCA F27440 27" TV
Sansui HDLCD3250 32 in. LCD TV Logo
93 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
