There is a grey and white dotted line horizontal across the laptop screen, about an inch from the top. When the laptop is first turned on, the line is green on the blue windows start up screen.
SOURCE: black screen with horizontal green lines
Hello yoyoxide.
from my experience can be something related with the video card. I recommend you the followig (Hardware diagnostics):
-Look for one of the discs that came with your computer, it should say (Drivers & utilities).
-Boot from the CD. If you don't know how to do it do the following:
1.Insert the Drivers&Utilities Disk.
2.Restart teh computer.
3. When you get the Dell logo, press F12
4.Select Boot from CD/CDRW-DVD (something like that).
-You will get a prompt to run the diagnosics.
-Just follow the wizard
-I recommend you to run diagnostics for everything.
-You will see if you have any problems with your hardware.
It seems that you have a pretty new laptop, so probably it's under warranty.
SOURCE: Dell Inspiron Screen Shake
sorry, can't tell you "no cost fix".
Either you've got a motherboard-screen cable failure(harsh, but not too bad) or you're
video card is fritzing. The green/grey line usually indicated a line break in a data line of the monitor cable. The fuzzy shaking is an indication that one of the sync signals may also be compromised.
To eliminate the video card as the problem... plug a monitor into the external video port, and see if the error is ghosted there.
If this doesn't work, Dell actually has some pretty good tools for you to use in troubleshooting it for yourself. The troubleshooter page begins here. There is a good video of using dell's built-in-to-laptops LCD screen test utility here.
Hope it helps you.
SOURCE: Horizontal Line running down my Laptop Computer Screen
You can try changing resolution to something else and then back.
You can see if your colors are 32-bit.
The fact that you "fixed" it is probably an coincidence. Once you start getting anomalies like that, it usually means a new screen.
SOURCE: white thin line running across horizontal on my hp laptop
You got a bad LCD screen. no immediate resolution aside from getting the LCD replaced. if your system still has warranty call Dell for replacement.
Hope it helps!
SOURCE: Laptop screen has horizontal white lines running across half the screen
Horizontal lines on bottom third of my Toshiba (Satellite Pro) Laptop with XP windows got fixed by flicking my finger on the laptop screen! Was it a loose connection? I don't know. Change of screen resolution did not help, Rebooting, did not help nor restoring to prior dates. Thank you guys.
