Canon PIXMA MX850 Multifunction Printer Logo
A
Anonymous Posted on Mar 19, 2017
Correcting B200 Error
Hi, I have a B200 error and I am attempting to isolate whether the issue is the logic board/ printhead or both for an MX850. The following parameters apply when switching the printer on at the top panel on/off switch: (i) B200 error appears; (ii) If I open the scanner bed with the power off and physically remove the printhead and switch printer on with the cradle lock handle down and lower the scanner bed, I do not receive the B200 error. Question: Does this establish the fault lies with the printhead or could it still be the logic board? That is, with the printhead removed, if the logic board is faulty will still give a B200 error? A related question is what is the standard technical procedure for isolating the printhead as the faulty mechanism? With thanks, Tim
Jessica Michael
Level 3:
Master:
  • Canon Master 459 Answers
  • Posted on Nov 21, 2018
Jessica Michael
Canon Master
Level 3:
Master:
Answers
459
Questions
Helped
305469
Points
1452
1) The Support Code b200 is an error message that may arise with the text which states "Printer Error Occurred", or "Contact the Service Center".
2) You will receive this message on your printer due to an electronic problem which may arise in the ink cartridges.
3) Open the top cover of your printer. Discard all the cartridges. Get rid of the printhead by lifting the lever which is placed just near the cartridge cradle, then take the printhead from the printer.
4) Re-insert the printhead back into its correct position, and ensure to lock the lever. Insert all the cartridges into their correct position, and confirm that there is no open door.
5) Unplug your printer cord from the electricity board, and keep it unplugged for a few minutes.
6) Let the printer cool down. Plug the printer back again.
5 Related Answers
Anonymous
  • 883 Answers
  • Posted on Aug 10, 2007
SOURCE: Scanner seems stuck and causes error
you can always try to install the printer on a friend's pc as a test of the printer...do you have the install cd? if not try canon's site to download it.
Anonymous
  • 310 Answers
  • Posted on Mar 03, 2008
SOURCE: Error Code B200 on Canon Pixma IP4300
Just restart the system and turn off the printer and turn on the printer it will work.
Check did you correctly placed your cartidges.
Anonymous
  • Posted on Nov 07, 2008
SOURCE: first start up of the day error code u140
said error 6A00 CODE
Anonymous
  • 37 Answers
  • Posted on Aug 02, 2010
SOURCE: Error Code
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Anonymous
  • 37 Answers
WHAT TO DO WHEN I HAVE AN ERROR CODE B200. i CANNOT PRINT AS THE MESSAGE IS CONTACT YOUR SERVICE PROVIDER. IS THERE A WAY I CAN FIX IT MYSELF////
Hi Kathleen,
to clear the Canon B200 error code:
Steps for 4+ Cartridge Printers
  1. Remove All Cartridges. Do whatever is necessary to remove the individual ink cartridges from your printer. In most cases this will be opening the lid of your printer and waiting for the cartridge cradle to move into the correct position.
  2. Remove the Printhead. This is easily achieved in most printers by simply lifting the orange/gray locking lever on the side of the cartridge cradle and then gently lifting the printhead from the printer.
  3. Reinstall the Printhead. Gently put the printhead back into your Canon Pixma printer and lock it into position firmly.
  4. Reinstall All Cartridges. Place all of the cartridges back into the printer and close any open doors. This makes sure that your printer is actively examining the reinstalled cartridges and printhead.
  5. Unplug the Printer. Physically remove your printers plug from the wall and leave it unplugged for 5+ minutes. This allows the printhead to cool and all residual electricity to leave the printer.
  6. Plug the Printer Back.
  7. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
Steps for 2 Cartridge Printers
  1. Turn the Printer off. When your printer is in this error state it will not let the cartridge cradle within the printer move. However resetting the printer should clear the error message temporarily allowing us to troubleshoot further.
  2. Turn the Printer Back on Again.
  3. Remove the Problem Cartridge. Whilst the Canon Pixma error messages do not tend to specify which cartridge is causing the problem, you should be able to have a rough idea based upon which cartridge was last replaced.
  4. Install a Replacement Cartridge. As the printhead is part of the cartridge, sadly there is no way to stop the B200 error without replacing the cartridge. I would recommend either installing a new cartridge or a previously used cartridge that you know to be functional.
  5. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
  6. If Necessary Replace the Other Cartridge. If the error persists with the new cartridge, it may be that the other cartridge has developed a fault and is the cause of the B200 support code. If at this point the error remians I can only recommend replacing the other cartridge.
I have an error message B200
Hi Kathleen,
3answers
What is error B200 & how can I fix it? Canon MP560
Error B200 refers to a bad printhead. You may have ran out of ink and the printer didnt catch the ink level on time, which caused it to glitch to error B200. There are a few tricks you may try to fix this, but most likely the printhead needs to be replaced. Your printer needs a printhead which is not expensive at all. $28.99 free shiping:
https://www.ebay.com/itm/371439052606
This is a video to try to reset b200 error: NEW Printhead For Canon QY6 0073 iP3600 iP3680 MP540 MP560 MP568 MP620...
3answers
How do I fix error code B200
Canon Printer Error Code B200 can also arise due to difficulties with your printhead, and one thing that you can try is to remove your printhead and clean it. Monitor your printer manual to learn how to do that. After you clean it, make sure that it's completely dry before you put it back in your printer. Maybe its Software Problem CALL PRINTER ERROR SUPPORT NUMBER ON BLOG.
7 Steps that resolve Canon Printer Error B200 Easily:-
1. Replace the problematic cartridges.
2. Remove and clean your printhead.
3. Reseat your printhead.
4. Check for obstructions.
5. Turn off the printer and open the print cover.
6. Replace the tank holder.
7. Press the Power and Copy buttons.
FULL BLOG- Canon Printer Error B200
Canon mg5250 -error code B200
B200 usually means that the printhead has failed. It's a generic "overtemperature detected" error that indicates that the thermal sensors inside the printhead have detected heating to the point where the printhead has probably failed. In a well-intentioned attempt to prevent further damage, the printer has shut itself off; however, by the time this occurs, the printhead is usually destroyed. The following video shows a likely next step: http://www.youtube.com/watch?v=I9uBEOMCd44
Canon pixma pro9500 mk2. error code b200. printhead problems. cannot access printhead, because it is locked in resting position due to error code. how do i get it to the middle? thanks!
PIXMA Pro 9500 MKII Error B200 = VH (Print Head Drive Voltage) is out of the specified value.
Need to :
- Replace print head and logic board at the same time.
or
- Replace Carriage Unit
or
- Power Supply Unit
1helpful
B200 error, what to do now?
The B200 error refers to a fault within the printhead but Canon recommend that a new logic board be fitted at the same time. Unfortunately the costs involved dont make it an economical repair and i would get another machine.
Srri buts thats the better option.
8helpful
WHAT IS THE PROBLEM WHEN APPEARS ERROR B200?
The error B200 refers to an overheat error of the printhead. however the head usually damages the logic board and both require replacing as a pair. Sorry but probably not an economical repair and a replacement machine is better.
2helpful
2answers
How can i fix error b200 ?
Hello thanks for using FixYa
According to Canon's documentation, Error b200 is simply listed as a printer error (not very descriptive). It is likely a hardware fault on a board, a physical hardware malfunction.
To solve it:
Turn off the machine, and unplug the power cord of the machine from the power supply. Again connect it and turn on.
If the problem is not resolved,
then best option is to take it back where you purchased it or contact Canon service center about the error code or
To get support by Canon on phone, then call at 1-800-OK-CANON (1-800-652-2666)
They will surely solve it.
For Further assistance, I am here to help,
Thanks, Keep Visiting FixYa
Regards:
Uxair Shah
8helpful
3answers
Does not print error b200
Helo, found on web. Good Luck :0)
The error code is standard for many of the late model MPxxx printers. The B200 error is "Printhead Temperature exceeded", What this means that while you were printing some document, either one or more of the printhead ink wells ran out of ink and the printing continued. Printhing without ink in the wells will OVERHEAT THE PRINTHEAD NOZZLES and can potentially burn the out. The printer has a built in temperature sensor to detect the ambient temperature and to monitor the temperature of the head. This data is always collected and monitored and saved in the EEprom data and the Service Test print data.
If the error will not go away once you have unplugged the priner for at least 5 minutes, then there is the possibility that you have already burnt out the head. Remove the printhead and use a 5x magnification glass to look VERY CLOSE at all of the nozzles to see if you can detect any possible burnt out nozzle.
It many come down to need a new printhead.
HERE IS THE LINK, IF YOU HAVE PROBLEMS.
http://www.fixyourownprinter.com/forums/laser/13864
old marine
old marine
ZJ Limited
ZJ Limited
