SOURCE: water dispencer does not stop when lever is
your control panel is sticking. it will get that way if you get your ice after you fill your drink. the way to fix this is to take it apart and clean it. the front panel comes off and there are 4 screws and then the whole unit can be removed.
SOURCE: The water dispenser does not work properly.
You have a bad main control board . The new pt # WR55X10656 . The dispensor board is not communicating with the control board . However , check this site to see if it can be replaced under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
Hello friend, thank you for allowing me to assist you!
It is a normal operation to receive water inside the dispenser after draining. This is part of the siphoning action of the drawer. You would just remove the drawer and empty the water out, then reattach the dispenser drawer. I hope this is helpful. -Matt
If the filter is clogged and you are not able to immediately replace it, leave the filter out so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing. However, in order to have filtered water, you will need to install a new filter.
All Genuine Maytag Water Filters retain beneficial fluoride and are NSF Certified for drastically reducing chlorine taste and odor, particulates, lead, mercury and cysts.
To ensure glass after glass of clean, refreshing ice and water, change your filter yearly or whenever the system light indicates.
about the filter:
http://assets.whirlpool.com/files/usr/animations/ANM000085.htm
The information above should get your water working. If not please listen for a solenoid buzz as you actuate the water in door function. No buzz either the dispenser is locked off or.... you have a valid warranty claim.
Thanks for choosing FixYa,
Kelly
Check that the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the "Unlock" or "Locked" button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds.
Check that the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the "Unlock" or "Locked" button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds. http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_adp.php?p_faqid=110&p_created=1147725595&p_sid=lTIkCMOi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzEmcF9wcm9kcz0xOTkmcF9jYXRzPSZwX3B2PTEuMTk5JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9d2F0ZXIgZGlzcGVuc29y&p_li=&p_topview=1
This is not a GE refrigerator. It is a Kenmore Elite 79572053110.
