My radio went mute or volume up/down itself suddenly/intermittent. Suspect shortings. FYI horn is also not working and i have removed fuse from fuse box to avoid continuous horn. Not sure has effect to radio or not. Please advice. Thx.
Yea the got a short somewhere. Horn fuse might or might not work something with the radio. I would say start with the horn. The horn is a controlled short sometimes shorts it self out. Open your steering wheel and work from there. For your radio look at all the fuses that you know work the radio and go from there. What kinda car is it year things like that would help because if it older wires, fuses, fusible links things like that go bad over the years. Especially if you run a lot of power through the wires that was made for that kinda power like upgraded speakers, headunit (radio) amps things like that. Older cars and trucks are make with cheap radio wires. hope this helps
