PrintCopy .infohttps://printcopy.info > code=SC390
Code: SC390; Description: TD sensor error 1. The TD sensor outputs less than 0.5V, 20 s after the TD sensor initial setting has been performed.
Missing: cod ‎' Must include: cod
Fixyahttps://www.fixya.com > ... > Ricoh
The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that ...
Copytechnethttps://www.copytechnet.com > 56632-sc-390-a
Sep 24, 2011 - I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed ...
This error is for a blocked magenta print head, so if you have done it allready, run the printer headcleaning routine, this is normaly found in the print driver under maintanance, or in the seperate software if supplyed
Most phones have a switch of some sort to adjust the volume - have you accidently turned it right down? Check the sides and bottom for a small slide or dial type switch and adjust it. There may be a symbol that is probably hard to see.
Sometimes when you get an error on a printer you can just press the stop button or some have a clear button to get rid of the error code.
If that doesn't work, try unplugging the printer from the outlet for a few seconds then plug back in to reset the error code.
In general the SC 860-900 refer to HD acces error. SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
The best I can find is that this is related to a malfunctioning cooling fan, I cannot find that specific code for your model, but all other 534 codes from that manufacturer are related to cooling fans
B010/B188 SC 534 Right fusing pressure motor HP error 1 - HP sensor defective B010/B188 SC 534 Right fusing pressure motor HP error 1 - IOB defective B010/B188 SC 534 Right fusing pressure motor HP error 1 - Motor defective B010/B188 SC 534 Right fusing pressure motor HP error 1 - motor drive bound B132/B200 SC 534 Duplex exhaust fan error - Paper exit fan motor M28 defective, indexed as 146, electrical component layout. B132/B200 SC 534 Duplex exhaust fan error - check and or replace fusing exhaust fan / paper blocking fan B132/B200 SC 534 Duplex exhaust fan error - replace duplex fan motors M29 or M30 B222/B224/G878 SC 534 2nd duct fan error - replace fan motor B230/B237 SC 534 Fusing exit sensor fan error, BICU defective B230/B237 SC 534 Fusing exit sensor fan error, Fan defective D014/D015 SC 534 Duplex unit fan error - Fuser exhaust fan blocked or has paper in it. D014/D015 SC 534 Duplex unit fan error - Duplex Unit fan obstructed D014/D015 SC 534 Duplex unit fan error - Fan harness disconnected or damaged D014/D015 SC 534 Duplex unit fan error - Fuser unit connector has paper obstruction D014/D015 SC 534 Duplex unit fan error - Replace duplex fan D023/D025 SC 534 Second duct fan error - replace the 2nd duct motor D023/D025 SC 534 Second duct fan error - replace the IOB D027/D029 SC 534 Second duct fan error - check connections and harness to fan D027/D029 SC 534 Second duct fan error - replace fan motor D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
My parents bought a Big Button Plus 20200 and people that call them cannot hear anything. We can hear the person calling but they can't hear us. Any suggestions?
