Brother MFC-7460DN Logo
Wendy Baker Posted on Mar 14, 2014
Fax from computer
How do I send a fax from the computer without having to print it?
David Hall
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on May 04, 2014
David Hall
Contributor
Level 1:
New Friend:
Answers
26
Questions
Helped
3319
Points
33
First, you will need a USB fax modem. Then you use Windows Fax & Scan program to create/forward new fax documents, or even send a file as a fax or email.
Setting up your external modem to work with an internet telephone line is simple. Simply put a 2 way splitter into the internet modem telephone jack. Plug your telephone into one input and the external fax modem into the other. Then you can even dial from your computer routine telephone calls too.
Need more explanation? Let me know.
Brother (MFC-7340 FAX, Scan, Print) - Can send FAX...
Be sure to have a noise filter on the ADSL line so the line quality is good enough to send and receive faxes.
tip
Can I send and receive faxes from my computer ?
Yes. You can. You will need a telephone line, a modem and a scanner, along with your computer. And before you can send and receive faxes from your computer, you will need to install the fax component. This fax component is not installed in Windows XP by default.
How to install the Fax Component:
Go to Start Button -> Control Panel -> Add/Remove programs ->Click on Add/Remove Windows Components ->Click in the Fax Services check box and click Next. Now you will see a Windows Component Wizard, which will setup the Fax service in your computer. Make sure the modem and telephone line are connected to your computer, along with the Scanner.
Now you have to configure the Fax component in your computer. In order to do that, you have to go to the Fax Console which is located at
Start Button ->All Programs->Accessories->Communications->Fax ->Fax Console
fax_xp.gif In the Fax console, click on the Tools Menu and select Configure Fax - this will start the Fax configuration wizard. Click Next to start configuring the fax service in your computer.
Enter your Name, Your Company's name and your fax (Telephone) number on the Sender Information page.
Your modem will be selected under Select Device for Sending or Receiving Faxes - if you have more than one modem, you will have to select the correct device to send and receive faxes in your computer. You will also have to specify if the send and receive options - whether you will manually answer incoming faxes or if you want your computer to automatically answer them for you.
Remember to Enter your Company's Name and Fax Number under Transmitting Subscriber Identification(TSID) and Caller Subscriber Identification (CSID). These fields are very important.
Now, under Routing Options, you will need to specify where incoming faxes are going to be stored in your computer. You can specify a local folder or just let it go to the default location, which is the Fax Console.
You can change these settings anytime you want by running the Fax Configuration Wizard again from Tools -> Configure Fax.
Sending Faxes from Your Computer
You can fax any document that is stored in your computer. You can also scan a document and fax it by sending it to the Fax Printer in your computer.
To fax a document from your computer, Click on the File Menu of the document and select Print. Then under print (or Print Setup), select Fax in the Printer Name box. This will open the Send Fax Wizard. You can also use the option called Send To and select Fax Recepient if you are using MS Office.
As soon as you hear your computer dialing, the Fax Monitor (as shown in the image below) will start up
fax_monitor_xp.gif How to Fax Scanned documents:
Another way to send a fax from your computer is to scan documents and then fax it through your Fax Printer. This can be made possible by using your scanner software. You can also fax from a scanner using the tools provided by Windows XP.
For this, go to the Control Panel and click on Printers and Other Hardware, then select Scanners and Cameras and then, double-click on the icon for your scanner to start the Scanner and Camera Wizard.
Then, on the Choose Scanning Preferences page, click Grayscale Picture and then click Preview to start the scanner.
Provide a name and location for the scanned document.
Now, go to the saved image which you scanned just now and right-click on it and select print - This will start the Photo Printing Wizard.
Click on the check box for the image to be faxed and select Fax as the printer you want to use.
When you finish the Photo Printing Wizard, the Send Fax Wizard opens and you proceed as described in the procedure for sending a fax from your computer.
Faxing from MS Outlook:
You can also fax from MS Outlook by adding the Fax Transport Service as an email account.
Receiving faxes on your computer.
Remember, you have already specified where the incoming faxes should be located and also how you wanted the incoming fax calls to be answered -manually or automatically. The Fax Monitor opens up automatically when the modem detects an incoming fax.
To view an incoming fax, go to the Fax Console and click on Inbox. Double-click on the fax entry you have just received and it will open up in the Windows Picture and Fax Viewer. Fax files are images in TIFF format so they cannot be edited. But u can print it out or email it to anybody else as an attachment.
on Jul 06, 2010 • Computers & Internet
I have attached the HP 4255 officejet with my computer and want to send the file directly from my computer via fax. how i can send directly without geting print . [email protected]
Well, you'll need a modem to send a fax. Either that, or an online faxing service. Your printer / scanner is only intended to either print files, or scan hard copies into files that can then be printed (or faxed). The printer itself does not fax.
Might I suggest the following online fax service, free of charge:
http://faxzero.com/
There are plenty of others.
-Jon
1helpful
I can't send a fax from my vista program with out printing out the fax first and sending it the old way, and that waste paper. in the xp or word 2003 I can go to the send in the file and the fax wizzard...
You need to go to printers and choose 'add a printer'. Under add printer, choose the printer called "MS FAX." That will install microsoft fax as a printer. Next, print your document by going to File, Print... (make sure it says "PRINT..." then you should see a selection screen, choose ms fax, and there you go. That should do it.
4helpful
2answers
Have no manual; need help using scanner and fax
Here is the link given to the user manual. that contains the optimum solution to your problem and maximum guidance.
http://www.devicemanuals.com/guide/All-in-One%20Products/HP/HP-PSC-950-All-in-One-Owners-Manual-==TVRFME56VTI=.html
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=34579
Pc fax transmission problem for bizhub 750?
The only solution may be a very expensive "Fax server".
You must have the fax kit in order to translate your print file to the fax language.
Is like trying to send an email without a modem, you may have access to a network but cannot talk the language required.
3answers
How to send fax from computer ?
Please follw the below steps:
To Fax From Your Word Processing Program1. Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software.
2. Open the document that you want to fax.
3. From the File menu, select Print. The Print window opens.
4. Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print.
5. You will be asked to provide the recipient's fax number and other assorted information as with a fax program.
6. The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
To Send a Fax From Fax Software1. Prepare the document that you want to fax.
2. Prepare a fax cover sheet, if desired.
3. Open your fax software - such as Microsoft Fax or Microsoft Exchangemag-glass_10x10.gif.
4. Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item.
5. Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed.
6. Indicate whether you wish to send a cover sheet.
7. When asked to attach the file, follow instructions to attach the file that you want to fax.
8. When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine.
9. When the connection is made, the fax will be sent.
Thank you.....
Hp officeject 6210 all in one printer
Sorry these printers has capability to send faxes from the computer only but not receive.
But your idea is right on wasting paper on printing incoming faxes, These days HP has launched a new model which can receive fax to your computer without wasting paper See the link bellow:
http://www.shopping.hp.com/webapp/shopping/store_access.do?template_type=product_detail&product_code=CB029A%23ABA&jumpid=oc_R1002_USENC-001_HP%20Officejet%20J6480%20All-in-One%20Printer&lang=en&cc=us
Take a look
How do I fax?
Sending a fax from your computer requires a fax modem and that your operating system be configured to allow you to send and receive faxes.
to send from fax software
step 1 Prepare the document that you want to fax. Step2 Prepare a fax cover sheet, if desired. Step3 Open your fax software - such as Microsoft Fax or Microsoft Exchange. Step4 Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item. Step5 Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed. Step6 Indicate whether you wish to send a cover sheet. Step7 When asked to attach the file, follow instructions to attach the file that you want to fax. Step8 When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine. Step9 When the connection is made, the fax will be sent. To Fax From Your Word Processing Program Step1 Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software. Step2 Open the document that you want to fax. Step3 From the File menu, select Print. The Print window opens. Step4 Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print. Step5 You will be asked to provide the recipient's fax number and other assorted information as with a fax program. Step6 The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
Norman Weimar
Norman Weimar
k24674
