Question about LG WD-1280FHD Front Load Washer
Washing machine my washing machine model is 1W711E what does it means?
    Scholar:
    New Friend:
  • 187 Answers
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Posted on Mar 15, 2014
6ya staff
SOURCE:
What does error code nd mean?
Hello, Vicky -
Is your washing machine a Samsung? If so, "ND" means "No Drain."
Read the information here:
https://removeandreplace.com/2016/03/22/samsung-washing-machine-error-code-nd-what-to-check-how-to-fix/
If I am incorrect in thinking your washing machine is a Samsung, you can Edit your question and add the make and model of your machine, so I or someone else can find an owner's manual for you and check the error codes for your particular machine.
Dec 24, 2017 | Washing Machines
What does the code E5 mean on a washing machine
Dont know what machine you have there are different meanings related to different makes and models, check out the link for a few of them
http://www.selfix-uk.co.uk/search-keyword.php
Apr 12, 2017 | Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
On a Whirlpool washing machine model # ghw9150p I have error codes E01, and F08 what or how do I find diagnostic code meanings.
go google and type in --fault codes for whirlpool washing machine model ghw 150p if one is available there will be a pdf version that you can down load
or go google and type in --workshop manual for whirlpool washing machine model ghw 150p
or you can make a call to an authorized service agent and ask what the codes mean
Oct 13, 2015 | Whirlpool Washing Machines
Daewoo washing machine model number DWC-LD1421 what dose the fault code LE mean for this model
The washing machine or washer dryer door has been detected as open or unlocked.
  • Close the door!
  • Check the door lock switch
  • Check the door latch
  • Check PCB
Mar 09, 2015 | Daewoo Washing Machines
Washing machine doesnt wash
Fault code 130 means the RPS (rotor position sensor) is not sending correct signals to the control board. The RPS is a small electronic device mounted on top of the motor copper stator. Either the wiring plug attached to the RPS has corroded the contacts or the RPS needs replacing. You will have to lie the machine down on front face to access the motor. Unscrew the centre bolt and remove the outer rotor bowl, then loosen the 4 hex. head bolts holding the stator about half way. Pull stator down so you can remove the wiring plug from RPS. Check for corrosion. If no corrosion then remove & replace the RPS.
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
Door on the Hoover washing machine, model H130E
make sure the tap is not broken off ,if the tap is good that means you switch is bad, replace it. hope this information could help you.
Apr 23, 2008 | Hoover H130E Front Load Washer
LG WD-1280FHD Front Load Washer Logo
131 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
