SOURCE: Flyback Transformer replacement instructions?
remove solder from all pins and squeeze clips to remove...
SOURCE: RCA P52937 Flyback Transformer question
The lead going from the flyback to that other device is a voltage divider or splitter as they're incorrectly referred to... To remove the leads press down firmly, twist and then pull up...
Bill
SOURCE: Were can i get the seal for the crt that is leaking coolant
If the front seal is leaking part number is 254599,the main seal,Thomson does not have ,replacement of the tube is required,mcm electronics should have the front seal,number is 1-800-543-4330
Testimonial: "kool"
