I have a KLH subwoofer and need a replacement fuse 5s 250 volt - I live in Tampa, Florida and have searched several places and still cannot find this fuse. Please Help. Nikki
Most likely the amp in the sub has blown. It will need repair or replacement. I'd take it to an expert in repairing amps, it's not a job for you unless you're experienced in troubleshooting these things.
The USA does not have a zip code. Each _City_ in the USA is assigned its' own individual zip code. IGo to this website: http://www.zip-area.com/ , select a State in the left column, then select a City. It will then give you the zip code for that City. The website also has a reverse lookup. All USA zip codes are 5 digits, so if you type in 33617 in the search box, it will tell you that is the zip code for Tampa, Florida. Large Cities have more than one zip code. For example, if you type 33615 in the search box it will also return Tampa, Florida. In fact if you type almost any thing starting with 336** it will return Tampa, Florida.
I'm not sure I understand the question. When you take the unit outside and turn it on, does it show you in Tampa, or Decatur? If it still shows you in Tampa check the satellite status in the tools menu, you may not be acquiring your current location.
If you're talking about the home location that is saved into your GPS as a waypoint, go into your favorite places list and delete the place named "home" then go to the location you want to save as your new home and press "where to" and then "home". Since there is no home saved, the GPS will ask if you want to save your current location as home. That should do it for you.
