Cannot see display bright on the unit
First, make sure that your brightness is turned up. You can access this from the menu by selecting "Display" then adjusting the display between 50% & 100%.
If the brightness is at 100% and the display is still dim, this is an indication that there is a problem with the backlight that lights up the LCD display from behind.
The backlight is integrated into the LCD display, so the entire display needs to be replaced. Was the unit dropped? If so, perhaps the LCD flex cable pulled out of the connector, slightly from one side, disconnecting the backlight. We strongly suggest that you don't try to repair the unit yourself. Additional damage can occur.
More information on LCD repair can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
