Sony KDL40S2010 Bravia Flat Panel LCD TV... will be on and running for 1/2 hour then turns off on it's on and will sometimes turn back on ... on it's own.
About 3 years old ... picture is still fine. Worth repairing? OH, also, About 2 years back the on/off switch on the top of the tv stopped working ... could it be an intermittent short in that switch causing it turn off on it's own?
Any ideas
If TV does not remain in standby and turns on itself then power switch on top of it could be defective and power supply board is also suspected. Take off its back cover and unplug top switch connector just to confirm is that cause of On-Off its own. If problem still exist then power supply board has problem and will be replaced. Let me know the results to move forward.
Removed back and disconnected the lead from the top switch assy. Seems to work ... 2 nights in a row the tv has stayed on for an extended time without a problem
Thanks for the suggesstion
lcd flat screen picture is greem
