Battery life:can I use my device while charging??
SOURCE: battery life under 5 hours
have you let the battery go totally flat as this is recomended to do every couple of months because if you dont let the battery go totally flat this stops the battery from full recharging and will cause bad cells in the batt so i would let hte battery totally flat till it wont even light phone up then fully charge for 16 hours see if this improves the battery if not then the charger is probably over heating and cutting off so you could replace the charge hope this is some help to you
SOURCE: Tocco F480 battery charging problems
i have had the same problem - try adjusting your display settings - if they are on the brightest and longest setting - go to settings and then dispaly and light setting and adjust them them - the battery life was really short (less than a day) i have changed all of my setting to a lower setting and now it lasts for days!! - really simple but it works ! :)
