Instructions say to remove 4 screws on back at top and top should slide back and be able to be lifted up and away. Top won't slide no matter what. What tricks should I try unit is about 3 years old...
You must slide it towards the front, not the back.
I am not budging
I had the same issue. After removing the set screws holding the top in place the top would not budge. My solution, like fixing an old TV's reception, get a thick towel out, and hit the top around all 4 edges with a hammer. Mine was stuck, hitting it with a hammer jarred it loose to slide it straight back using the plastic tabs on the back. Worked for me, YMMV. Good luck
Http://youtu.be/tZUHy_AOIY0
SOURCE: How do I remove the top of my LG WM2496HSM washer?
Code will not tell which is faulty. To remove top: after removing three phillips head screws (leaving the L shaped part attached to the top) slide the top back about one and a half inches and lift it straight up.
SOURCE: Lg top load washer e6
E6 is listed by Samsung as :- Water temperature rising/falling too quickly. Check thermistor.
